problem in configuring OSPF
ashookoul
I am facing a problem in configuring OSPF
Actually in one of our location the LL provider has provided half LL and half RF connectivity in between is a Lunix based convertor which converts LL into RF.The RF part connectivity is configured in Local Lan.Now the problem is how will i configure OSPF in 1751 router . Is there solutin for this as i don't want to configure ospf in convertor as that is placed at unmanged place.The diagram attached with will give the detailed information about the connectivity.
thanks
globalnettech
Level 5
Level 5
if I understand your question/drawing correctly, you want OSPF connectivity between your 3745 and your 1751 routers without having to configure it on the convertor ? You might want to consider an OSPF tunnel between both routers, the configs would look like this:
hostname 1751
interface Loopback0
ip address 10.1.1.1 255.255.255.0
interface Tunnel0
tunnel source Loopback0
tunnel destination 10.3.3.3
interface Serial0
ip address 172.16.15.1 255.255.255.0
encapsulation ppp
router ospf 1
network 10.1.1.0 0.0.0.255 area 0
network 192.168.1.0 0.0.0.255 area0
ip route 0.0.0.0 0.0.0.0 172.16.15.2
hostname 3745
interface Loopback0
ip address 10.3.3.3 255.255.255.0
interface Tunnel0
ip address 192.168.1.3 255.255.255.0
tunnel destination 10.1.1.1
interface Serial1
ip address 172.16.25.3 255.255.255.0
router ospf 1
network 10.3.3.0 0.0.0.255 area 0
network 192.168.1.0 0.0.0.255 area 0
ip route 0.0.0.0 0.0.0.0 172.16.25.2
GNT
desai.jaideep
Level 5
Level 5
What is the relevence of your 1751 router in your network?Is it acting as a gateway?Are you planning to have 1751 for backup?
I suggest placing the 1751 before the switch.i.e, install an WIC-1ENET (1 ethernet) in your 1751, Create routing between the converter and the router.
This should solve your purpose.
Pls rate helpful posts.
JD
