ASA 5505 8.3+ NAT question
ChuckHaynes
Level 3
Level 3
Current config: Port 0 is outside (VLAN 2 - going to ISP) and Ports 1-7 are inside (VLAN 1 - going to internal LAN devices). The ASA version was upgraded to 8.3.1 a few months back and everything is working properly. However, we are now wanting to add a WAP to Port 7 (which is currently not being used). We want the WAP traffic to only be able to access the Internet and nothing on the LAN or WAN. I have created another VLAN (3) and assigned it to Port 7. I've blocked traffic from it to VLAN1. I've also configured DHCP and DNS - but I'm having a problem with NAT. I know NAT was changed in ASA 8.3, and that's what's giving me problems. I am trying to add this line: nat (dmz-wireless) 1 192.168.69.0 255.255.240.0 - but it tells me the command has been depreciated. I have done a "help nat" and read several web documents, but I'm still not fully understanding it. I am basically looking for the 8.3+ equivalent of that command. We do have an existing NAT line for our inside traffic, however, I don't think the addition of this WAP will affect that. Thanks.
Jon Marshall
NAT on 8.3 onwards is very different and there are basically 3 separate sections where you can place your dynamic PAT statement.
People usually do it in either section 2 or section 3. You need to be careful because the section you place it in can affect other things,.
So I'll link to a document by Jouni Forss which is a post 8.3 NAT guide which is, in my opinion,  one of the best documents on this site to be honest. He recommends doing dynamic PAT in section 3.
It's a relatively quick read but if you are in a hurry there are examples for both dynamic PAT in section 2 and section 3.
I would recommend giving the whole thing a read and you may be able then to relate it to what you already have on your ASA -
https://supportforums.cisco.com/document/132066/asa-nat-83-nat-operation-and-configuration-format-cli
if your still having problems after this then please post back.
If no one else has helped out I will check this thread out in the morning.
Jon
Jon Marshall
Jon
Thanks, that pointed me in the right direction. I also found this link at the bottom of the page you linked to (in the comments).
https://supportforums.cisco.com/document/33921/asa-pre-83-83-nat-configuration-examples
