ASA 5505.Any way to assign external ip to internal server?
valeriy.vainkop
I have 3 external ips from my isp:
222.222.222.221
222.222.222.222
222.222.222.223
The first one I use to provide internet access to my office.
The other two I'm going to use for the following:
I'm going to deploy a server in internal network which must have 2 external ips on his network interface (& one internal ip on the second,but that's ok:))
I cannot put an extra network switch before asa & plug this server there: this server is virtual & is on esxi host in internal network.
External ips must be assigned to servers' interfacw,bot just forwarded there (ms direct access requirement).
Please help my with config as I'm also a Cisco newbie :(
My current config:
ASA Version 8.4(3)
hostname msk-office
domain-name remote.firma.ru
enable password 9tpvMyzTwlokMPIT encrypted
passwd 9tpvMyzTwlokMPIT encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 172.16.0.1 255.255.0.0
interface Vlan2
nameif outside
security-level 0
ip address 222.222.222.221 255.255.255.248
boot system disk0:/asa843-k8.bin
ftp mode passive
clock timezone MSK/MSD 3
clock summer-time MSK/MDD recurring last Sun Mar 2:00 last Sun Oct 3:00
dns domain-lookup inside
dns server-group DefaultDNS
name-server 172.16.0.20
name-server 192.168.1.20
name-server 222.222.222.10
name-server 222.222.222.20
object network dcenter1-internal-network
subnet 192.168.1.0 255.255.255.0
object network msk-office-internal-network
subnet 172.16.0.0 255.255.0.0
object network NETWORK_OBJ_172.16.0.0_16
object-group network obj_any
access-list outside_cryptomap extended permit ip 172.16.0.0 255.255.0.0 object dcenter1-internal-network
access-list global_access extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-647.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_172.16.0.0_16 NETWORK_OBJ_172.16.0.0_16 destination static dcenter1-internal-network dcenter1-internal-network no-proxy-arp route-lookup
nat (inside,outside) after-auto source dynamic any interface
access-group global_access global
route outside 0.0.0.0 0.0.0.0 222.222.222.220 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 0.0.0.0 0.0.0.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
protocol esp integrity sha-1
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto map outside_map 1 match address outside_cryptomap
crypto map outside_map 1 set peer 111.111.111.111
crypto map outside_map 1 set ikev1 transform-set ESP-AES-256-SHA
crypto map outside_map 1 set ikev2 ipsec-proposal AES256
crypto map outside_map interface outside
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 30
encryption 3des
integrity sha
group 2
prf sha
crypto ikev2 enable outside
crypto ikev1 enable outside
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
telnet 0.0.0.0 0.0.0.0 inside
telnet 0.0.0.0 0.0.0.0 outside
telnet timeout 20
ssh timeout 5
console timeout 0
management-access inside
dhcpd dns 172.16.0.20 192.168.1.20
dhcpd domain ad.firma.ru
dhcpd update dns
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy GroupPolicy_111.111.111.111 internal
group-policy GroupPolicy_111.111.111.111 attributes
vpn-tunnel-protocol ikev1 ikev2
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
tunnel-group 111.111.111.111 type ipsec-l2l
tunnel-group 111.111.111.111 ipsec-attributes
ikev1 pre-shared-key *****
ikev2 remote-authentication pre-shared-key *****
ikev2 local-authentication pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
20 Replies 20
>>If what you want to achieve requires you to order something additonal, then it just highlights that you didnt prepare well >>enough for the task.
ok, I'll explain it like that: I don't think that for "passthrough"ing one ip into lan additional extarnal ip is an obligatory requirement.
>>If you have traffic coming from the internet to a single IP address, and that hits the outside interface of your ASA... but you >>want some traffic to go to the internal network and some traffic to go to the TMG server, how does the ASA know what to do?
First of all I can use several interfaces, not only one. & thought it'd be the same as just using one port of asa for regular outside & one as a switch port (so it's basically the same as it is in my setup, but 2nd isp cable will go into asa, not to big office switch)
>>In your "scenario" where you have split the ISP cable... I cant even see how that would work
Think more, it just works & it's simple.
>>but you may as well throw away the ASA though because its not providing any protection
When I assign external IP to internal server all traffic goes to it & there's a TMG+UAG on it, so it's protected not by asa, yes. Other localnetwork machines are protected by asa & nothing from outside can reach them as external ip of DA server leads only to it & nowhere else in lan. As I see it as an additional measure maybe it's possible to use different vlans for it?
patrick.preuss
Getting additional IPs is one way and is a valid soulution.
I am not shure about 5505 but the bigger once can run in two modes.
Routed (The Default mode) or Bridged (Transparent Firewall).
Maybe you should read a little about this mode ..
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/interface_complete_transparent.html
It depends on what you whant to achive.
And only one mode at a Time.
>>It depends on what you want to achive.
What I'm trying to achieve is written in my first post
Thanks for the article, started reading
Valeriy,
as allways. we dont know the whole story. so we can give a hind here and there.
ASA can do many things. They are build for simple things and more complex things.
Like Network merges with overlapping Networks.
So as allways it depends.
Routing additional addresses also valid soulution and the transparent mode also. both have pros and cons, so it is up to you to decide witch fits better.
If things help please assign Points;-)
Patrick
On my 5505 this is the solution for me (at least it goes through asa, not around it as it was):
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 217.173.69.70 255.255.255.248
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
After that connected interface Ethernet0/2 & internal big lan switch & voila!
Howether this doesn't work in my 5510 as it doesn't have a switchport & vlans are configured in some other way & as I understand I must configure some "trunking" which I never did before Any help will be much appreciated!
Thanks man, you helped me A LOT!
