ASA 5505.Any way to assign external ip to internal server?
valeriy.vainkop
I have 3 external ips from my isp:
222.222.222.221
222.222.222.222
222.222.222.223
The first one I use to provide internet access to my office.
The other two I'm going to use for the following:
I'm going to deploy a server in internal network which must have 2 external ips on his network interface (& one internal ip on the second,but that's ok:))
I cannot put an extra network switch before asa & plug this server there: this server is virtual & is on esxi host in internal network.
External ips must be assigned to servers' interfacw,bot just forwarded there (ms direct access requirement).
Please help my with config as I'm also a Cisco newbie :(
My current config:
ASA Version 8.4(3)
hostname msk-office
domain-name remote.firma.ru
enable password 9tpvMyzTwlokMPIT encrypted
passwd 9tpvMyzTwlokMPIT encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 172.16.0.1 255.255.0.0
interface Vlan2
nameif outside
security-level 0
ip address 222.222.222.221 255.255.255.248
boot system disk0:/asa843-k8.bin
ftp mode passive
clock timezone MSK/MSD 3
clock summer-time MSK/MDD recurring last Sun Mar 2:00 last Sun Oct 3:00
dns domain-lookup inside
dns server-group DefaultDNS
name-server 172.16.0.20
name-server 192.168.1.20
name-server 222.222.222.10
name-server 222.222.222.20
object network dcenter1-internal-network
subnet 192.168.1.0 255.255.255.0
object network msk-office-internal-network
subnet 172.16.0.0 255.255.0.0
object network NETWORK_OBJ_172.16.0.0_16
object-group network obj_any
access-list outside_cryptomap extended permit ip 172.16.0.0 255.255.0.0 object dcenter1-internal-network
access-list global_access extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-647.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_172.16.0.0_16 NETWORK_OBJ_172.16.0.0_16 destination static dcenter1-internal-network dcenter1-internal-network no-proxy-arp route-lookup
nat (inside,outside) after-auto source dynamic any interface
access-group global_access global
route outside 0.0.0.0 0.0.0.0 222.222.222.220 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 0.0.0.0 0.0.0.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
protocol esp integrity sha-1
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto map outside_map 1 match address outside_cryptomap
crypto map outside_map 1 set peer 111.111.111.111
crypto map outside_map 1 set ikev1 transform-set ESP-AES-256-SHA
crypto map outside_map 1 set ikev2 ipsec-proposal AES256
crypto map outside_map interface outside
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 30
encryption 3des
integrity sha
group 2
prf sha
crypto ikev2 enable outside
crypto ikev1 enable outside
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
telnet 0.0.0.0 0.0.0.0 inside
telnet 0.0.0.0 0.0.0.0 outside
telnet timeout 20
ssh timeout 5
console timeout 0
management-access inside
dhcpd dns 172.16.0.20 192.168.1.20
dhcpd domain ad.firma.ru
dhcpd update dns
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy GroupPolicy_111.111.111.111 internal
group-policy GroupPolicy_111.111.111.111 attributes
vpn-tunnel-protocol ikev1 ikev2
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
tunnel-group 111.111.111.111 type ipsec-l2l
tunnel-group 111.111.111.111 ipsec-attributes
ikev1 pre-shared-key *****
ikev2 remote-authentication pre-shared-key *****
ikev2 local-authentication pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
20 Replies 20
valeriy.vainkop
Anyone? :)
What I understand is that you have one virtual host which is in your LAN and that needs to be accessible from Internet
If that is what you want then you need to configure a static NAT with a specific public IP say for example....
#static (inside,outside) 222.222.222.223 10.1.2.28 netmask 255.255.255.255
Please rate the helpfull posts.
Naidu.
Unfortunately the situation is more complicated than that:
Server must have public IPs configured on its' network interface, NOT just nated there. I mentioned it in my first post.
Is there any way to accomplish that?
Then you must use DMZ interface and put that server in the DMZ.
This server should have 2 network adapters:
1st must have 2 public IPs on it
2nd must be in local network (172.16.0.0)
I'll be like that if I configure DMZ interface?
As you can see in my config I didn't configure it Can you tell me how to do that in order to accomplish what I need?
Thanks in advance!!
Jeff Van Houten
Level 5
Level 5
how many nics in the esx host? Couldn't you dedicate a physical nic to the external address space then attach that nic to a switch on the same segment as the external address space of the Asa?
This is a well known workaround, not a solution. But thanks
ai.solutions
Why must the public IP appear on the server's NIC? Unless there is a very good reason, the one-to-one NAT will work in almost all cases.
Also consider the security implications of having two ingress paths into your local LAN.
This is a Microsoft Direct Access requirement, do you think it's a good enough reason?
http://blog.concurrency.com/infrastructure/uag-sp1-directaccess-ip-addressing-the-server/
I'm so tired of telling people why I need this, no solution, only workarounds Some Cisco technician reading this forum could at last honestly say that it's impossible!!!
About security: I assign these external IPs to machine with MS UAG+TMG in internal network & in my opinion it's secure enough, because external traffic can go in/out only to/from these machines & not to/from any other machines in my internal network. Why do you think it's not secure?
ai.solutions
Order a /30 subnet from your ISP. Have it routed to your existing public IP. A /30 will give you 2 usable addresses.
Then create a new vlan on the Asa and associate it with one of your free interfaces. Connect that interface to your servers external nic. Apply one of the /30 addresses to the ASAs interface and the other address to your servers nic. Apply appropriate firewall rules to your ASA interface.
Then you can now access that server directly from the Internet using its new IP.
Valeriy
BTW why not use the ASA for VPN or am i missing something ?
You have a lot of possibiliies to build vpns.
Cheers Patrick
We switched to Direct Access completely, because Direct Access is much better than VPN, especially for mobile users on Win7 (& all of our clients currently are on Win7).
Here are several reasons to switch to DA:
1) DA starts connection before login no matter which user you choose & to which network you're connected. There's no need to script or configure smth for that becasue Win7 have DA client capabilities embedded & it's very reliable (tested )
2) DA uses one of 3 types of tunnels depending on the situation switching from one to another & that's why it can connect you to corporate network from anywhere avoiding problems with public wifis blocking some ports & etc.
Well this also looks like some kind of workaround for me. Seriously, is it possible to accomplish what I need without ordering something additional from ISP??!!
Now I splitted ISP cable with a small switch & one cable from there goes to ASA's outside interface & the second one is plugged into big office switch directly. Works perfectly, but it's not quite secure,yeah?
Getting additional IP addresses isnt a workaround. This is how it is done properly.
If what you want to achieve requires you to order something additonal, then it just highlights that you didnt prepare well enough for the task.
Think about this. If you have traffic coming from the internet to a single IP address, and that hits the outside interface of your ASA... but you want some traffic to go to the internal network and some traffic to go to the TMG server, how does the ASA know what to do?
In your "scenario" where you have split the ISP cable... I cant even see how that would work... but you may as well throw away the ASA though because its not providing any protection.
