ASA 5505 CLI Port Fowarding
Hi to all the community, I have Instant messaging service installed that uses port XXXX need to do a port fowarding in my ASA-5505
I have created the network object pointing to a fixed IP 192.168.1.5/24
object-group network IM-COM
 description IM-Server
 network-object host 192.168.1.5
Create
object-group service IM_PORTS
 service-object tcp eq XXXX
My ACL
access-list IM-COM extended permit tcp any host 192.168.1.5 eq XXXX
and NAT rule
static (outside,inside) 192.168.1.5 [External IP] netmask 255.255.255.255
But I can't get my phone yet get connected over the Internet, please I could use some help with this matter thanks to all for reading this
7 Replies 7
Jon Marshall
Which version of code are you using ?
Assuming 8.2 or earlier by the looks of your static NAT -
1) the acl should reference the public IP not the private IP
2) change your static statement to -
static (inside,outside) <external IP> 192.168.1.5 netmask 255.255.255.255
note if you want to use the same external IP for other port translations then you can do -
static (inside,outside) tcp <external IP> <port number> 192.168.1.5 <port number> netmask 255.255.255.255
Up to you.
If you are running 8.3 or later code then please say as the above won't work.
Jon
I'm Using the ASA 8.2 try the code but din'd work saids:
Firewall(config)# static (inside,outside) tcp [Public IP] [XXXX] [local IP] [XXXX] netmask 255.255.255.255
ERROR: Static PAT using the interface requires the use of the 'interface' keyword instead of the interface IP address
I already fix the ACL Im checking the static route
Just try
static (inside,outside) tcp interface XXXX 192.168.1.5 XXXX netmask 255.255.255.255
from this discussion
https://supportforums.cisco.com/discussion/10391761/static-entry-asa
Didn't work either
Thanks a lot for your time
Yes, if the public IP is the interface IP you need to use the "interface" keyword which you worked out.
Are you sure you have allowed all the necessary ports ?
Can you post your current configuration.
Jon
I just open in the ACL
access-list IM_COM extended permit tcp any host [Public_ IP] range XXXX YYYY
and static to
static (inside,outside) tcp interface 5222 192.168.1.5 XXXX netmask 255.255.255.255
I know of two ports only that need to be open 5222 and 7777; I know I can reach the ASA5505 because I have a ping so any Ideas please?? Thanks a lot for taking so much time for me truly J. Hopefully this will help once again thanks.
interface Vlan1
 nameif inside
 security-level 100
interface Vlan2
 nameif outside
 security-level 0
 ip address [Public IP] [Netmask]
 service-object tcp eq 5222
access-list IM_COM extended permit tcp any host [public_ip] range 5221 10015
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface 5222 192.168.1.5 5222 netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 [*******************] 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
Have you added statics for both ports ?
If you have based on what you have posted it looks fine.
You could try running a packet tracer to see what the firewall is doing ie.
"packet-tracer input outside tcp 8.8.8.8 12345 <public IP> 5222"
and post the results.
Jon
I just came in the datacenter I have a COMCAST Modem facing the internet an my firewall behind him, tomorrow I'll check the modem ports to see if they're closed. Im like a week old here so Im sorry for this anyway Im not going to close the discussion yet. I'm very gratefull for all.see you guys tomorrow.J
Could you please clarify for me about
you mean for inside and outside? I have only one static the one you see in the conf.
I'm sorry It took me sometime, to reply but the COMCAST Modem well was a mess in the internal LAN, now it's fin and I'm getting he firewall from both sides, for some reason it's droping the packets here I paste the results of the packet-tracer any help deeply appreciated, it's the ASA ver 8.2(5)
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   0.0.0.0         0.0.0.0         outside
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Sh run
ftp mode passive
 description IM-COM Server
access-list IM extended permit tcp any host [public IP] range 5221 10015
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 10.1.10.1 1
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
