BGP across DMVPN Tunnels
Brian Green
I currently have, in a lab environment, 2 routers (a 2921 and a 3945) that establish a DMVPN tunnel between them.  Externally, statics are used to define the next hop to eventually reach the other end and establish the DMVPN.  BGP is supposed to advertise the routes within the Tunnel to the other end - that's where I'm having problems.  I have a basic BGP configuration on both ends, using Passive connection as the transport-mode (as, for scalability, the spoke is part of a peer-group), but show bgp neighbor doesn't show me anything.  Both the external link and the DMVPN tunnel are inside VRFs - not the same one.
Both the Hub & Spoke router are in different Autonomous Systems, and have different router-id values (I've used their internal IP Address for that).
As you may have guessed, I'm not a BGP expert - I'm picking this up as I go.  Any idea what I could be missing?
Brian
Hello
can you post the configuration for this please?
res
paul
Kind Regards
Paul
Basic Config:
HUB:
  GigabitEthernet0/0
    9.9.9.1 255.255.255.0
    vrf OUTER
  GigabitEthernet0/1
    10.10.10.1 255.255.255.0
    vrf INNER
  DMVPNTunnelInterface
    2.1.1.1 255.255.255.0
    vrf INNER
SPOKE:
  GigabitEthernet0/0
    8.8.8.1 255.255.255.0
    vrf OUTER
  GigabitEthernet0/1
    10.10.1.10 255.255.255.0
    vrf INNER
    2.1.1.10 255.255.255.0
    vrf INNER
When the Interface for the DMVPN is brought up, the router connect over vrf OUTER, the SPOKE using interface 8.8.8.1 to connect to 9.9.9.1  Once the DMvPN shows as UP, the SPOKE can ping to the HUB`s DMVPN address on vrf INNER – ping vrf INNER 2.1.1.10 and vice versa.
HUB:
router bgp 61100
  bgp router-id 10.10.10.1
  bgp log-neighbor-changes
  bgp deterministic-med
  bgp listen-range 2.1.1.0/24 peer-group SPOKES
  bgp listen limit 1000
  bgp graceful-restart restart-time 120
  bgp graceful-restart stalepath-time 360
  bgp redistribute-internal
  address-family ipv4 vrf OUTER
    redistribute static
  exit-address-family
  address-family ipv4 vrf INNER
    network 10.10.10.0 mask 255.255.255.0
    redistribute connected
    redistribute static
    neighbor SPOKES peer-group
    neighbor SPOKES transport connection-mode passive
    neighbor SPOKES version 4
    neighbor SPOKES timers 10 60
    neighbor SPOKES send-community both
    neighbor SPOKES route-reflector-client
    neighbor SPOKES next-hop-self
    default-information originate
  exit-address-family
SPOKE:
router bgp 61500
  bgp router-id 10.10.1.10
  no bgp fast-external-failover
  neighbor 2.2.2.1 remote-as 61100
  address-family vpnv4
  exit-address-family
    network 10.10.1.0 mask 255.255.255.0
    neighbor 2.1.1.1 remote-as 61100
    neighbor 2.1.1.1 transport path-mtu-discovery
    neighbor 2.1.1.1 transport connection-mode passive
    neighbor 2.1.1.1 update-source DMVPNTunnelInterface
    neighbor 2.1.1.1 version 4
    neighbor 2.1.1. 1 timers 10 60
    neighbor 2.1.1.1 activate
    neighbor 2.1.1.1 send-community
    neighbor 2.1.1.1 soft-reconfiguration inbound
  exit-address-family
