ASA 5505 PPPoE to Leased Line
Mohammed Yusuf
we are migrating from PPPoE to leased line and Asa has got PPPoE settings in the config.
we have got IP address and gateway on the leased line and I wanted to know how I could
remove PPPoE settings and add leased line IP address and gateway etc.
thanks,
Hello Mohammed,
basically, this is what you add to the leased line interface:
interface Vlan3
nameif outside
security-level 0
ip address 192.168.10.11 255.255.255.0
interface Ethernet0/0
switchport access vlan 3
route outside 0.0.0.0 0.0.0.0 192.168.10.12
Can you post the current config of your ASA ?
Is there a command that shows PPPoE config only like sh run | VPdn I am not sure.
Do you know otherwise I have got really big config.
thanks,
Mohammed,
when you do a show running-config ?' it willl list the commands that are available. If you don't find the right one, just post the entire config...
As requested
vpdn group DSL request dialout pppoe
vpdn group DSL localname abc8723@abc
vpdn group DSL ppp authentication chap
vpdn group abc request dialout pppoe
vpdn username abc8723@abc password Lifeisgood store-local
interface Vlan2
nameif outside
security-level 0
ip address pppoe setroute
I am assuming that I need to negate the above statements and add few more steps.
no vpdn group DSL request dialout pppoe
no vpdn group DSL localname abc8723@abc
no vpdn group DSL ppp authentication chap
no vpdn group abc request dialout pppoe
no vpdn username abc8723@abc password Lifeisgood store-local
no ip address pppoe setroute
and add your suggestions.***********
interface Vlan2
nameif outside
security-level 0
switchport access vlan 2
Please let me know if It is ok to run it?
