ASA 5510+: Can I change the default hostname in the default factory config
mdp133001
Hello Experts,
Is there any way to change the default hostname in the default factory config of the ASA so that whenever I bring ASA to the default factory config I get the hostname provided by me
Tushar Bangia
Hi MDP,
As per Cisco ASA design if you erase/clear the memory it will go default hostname and this has been soft coded to the ASA IOS/Image.
Hence we will not be able to hardcode a hostname as per our requirement on the box, a factory default to Cisco ASA will always leave you with default hostname.
Tushar Bangia
PS - Please rate the post if you find it helpful.
Thanks Tushar for you reply.
Do you mean that the configuration is in the IOS and not on the box(in some hidden dir)?
