asa 5510 vpn not connecting
I am getting the error "cypto map policy not found" when attempting to connect the VPN. My running config is below.
I am attempting to connect from a draytek 2820.
Please advise:
ASA Version 8.2(5)
hostname ciscoasa
enable password H4jV5cejsN/7lxxb encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 192.168.15.0 Warehouse description Warehouse
interface Ethernet0/0
nameif outside
security-level 0
ip address 195.171.223.67 255.255.240.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.32.233 255.255.255.0
interface Ethernet0/2
nameif inside2
security-level 50
ip address 192.168.33.1 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
nameif management
security-level 100
management-only
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 8.8.8.8
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list outside_1_cryptomap extended deny ip 192.168.32.0 255.255.255.0 Warehouse 255.255.255.0
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit ip 192.168.32.0 255.255.255.0 Warehouse 255.255.255.0
access-list inside2_access_in extended permit ip any any
access-list inside_access_out extended permit ip any any
access-list inside2_access_out extended permit ip any any
access-list inside2_access_out extended permit ip interface inside2 interface inside
access-list inside2_access_out extended permit tcp any any
access-list inside_nat0_outbound extended permit ip 192.168.32.0 255.255.255.0 Warehouse 255.255.255.0
access-list outside_access_in extended permit ip Warehouse 255.255.255.0 192.168.32.0 255.255.255.0
pager lines 24
logging enable
logging trap warnings
logging asdm informational
logging host inside 192.168.32.1
mtu outside 1500
mtu inside 1500
mtu inside2 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
nat (inside2) 1 0.0.0.0 0.0.0.0
static (inside,inside2) 192.168.0.0 192.168.0.0 netmask 255.255.0.0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
access-group inside_access_out out interface inside
access-group inside2_access_in in interface inside2
access-group inside2_access_out out interface inside2
route outside 0.0.0.0 0.0.0.0 195.171.223.65 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.32.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set connection-type answer-only
crypto map outside_map 1 set peer 81.137.231.247
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp enable inside
crypto isakmp enable inside2
crypto isakmp policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
dhcpd address 192.168.33.100-192.168.33.200 inside2
dhcpd dns 192.168.32.1 192.168.32.2 interface inside2
dhcpd option 3 ip 192.168.33.1 interface inside2
dhcpd enable inside2
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
vpn-tunnel-protocol IPSec
tunnel-group 81.137.231.247 type ipsec-l2l
tunnel-group 81.137.231.247 ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:1ea6dbd4b54aad68c1215b9a359e71bc
: end
asdm location Warehouse 255.255.255.0 inside
5 Replies 5
The exact errors i am getting are
Reason: crypto map policy not found
=81.137.231.247, IP = 81.137.231.247, Removing peer from correlator table failed, no match!
=81.137.231.247, IP = 81.137.231.247, QM FSF error (P2 struct &0xab3b3878, mess id 0xf571b0d0)!
matching crypto map entry for remote proxy 192.168.16.0/255.255.255.0/0/0 local proxy 192.168.32.0/255.255.255.0/0/0 interface outside
HELP!!
Christian
Unless I'm missing it, I see that your outside crypto map isn't permitting any traffic to bring the tunnel up:
HTH,
John
HTH, John *** Please rate all useful posts ***
Hi John,
thanks for your reply.
I  spotted that shortly after changed this line to permit however it still doesnt work
I also notice the error -81.137.231.247, received encrypted packet with no matching sa. dropping
This is directly after a phase 1 complete.
Does the other side suppport 3des-sha?
naresh.narang
Use debug crypto isakmp to see which one you are missing and then add that.
