Licensing and ISR-G2
Router A Serial number = aaaaaaaaa ( IP BASE )
Router B Serial number = bbbbbbbbb ( SECK-9 )
RouterA is deployed in CityA while RouterB is deployed in CityB . Currently both routers are configured with static routes and NAT entries and now there is a requirement for some IPSEC VPN in CityA ( RouterA ) , I will need to purchase one Security technology pack to resolve this or I can swap the harwdare physically as there seems to be no requirement of Security pack on another site .
Is there a way I can swap technology pack by the help of cisco ? so that I may not need to purchase extra license or replace boxes physically . Idea is to have a security pack on RouterA and IP Base on Router B .
paolo bevilacqua
I think there is no way, but you can try asking licensing@cisco.com
dumesh
If you are sure that Router B does not need seck9 licesne, probably swapping the hardware is the way to move forward.
However, as Paolo suggested, Licensing team could confirm things for you.
Cheers,
Dheeraj
