ASA 5512 v8.6 - Need to add a new subnet to existing VPN - help!
adzrobo
Hello everyone, I have just been tasked with adding a new subnet to an existing VPN already set up on the ASA. I have no experience of Cisco firewalls and I've exhausted google with my searches so I'm hoping the community can help. BTW we have no access to ASDM so cli only.
11 Replies 11
Francesco Molino
Have you restarted the vpn connection?
Can you share the output of show crypto ipsec sa please?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
 n/a
I am not sure what ASDM does under the hood when you add a new subnet to an existing VPN connection and click 'OK', but try:
--> no crypto ikev1 enable OUTSIDE
--> crypto ikev1 enable OUTSIDE
I managed to get ASDM installed last night so I now have access to this. Any articles or advise so I can use this?
adzrobo
n/a
adzrobo
After a day of troubeshooting I think I've narrowed down the issue but I dont know how to change this. The only difference between the working vpn tunnel show this on the tracepackets:
Phase: 6
Type: NAT
Subtype:
Result: ALLOW
Config:
And this on the one that isn't working:
Phase: 6
Type: NAT
Subtype:
Result: ALLOW
Config:
object network obj_any
nat (INSIDE,OUTSIDE) dynamic interface
Additional Information:
So it seems that the NAT exemption rule is being overridden by the auto NAT policy - any help would be great.
possibly your NAT rules are out of order. Put the dynamic entry in section 2:
nat (INSIDE,OUTSIDE) 2 dynamic interface
Unfortunately this is already the case. Like I say I already have one working tunnel but the second one I’ve added just won’t push the packets through the tunnel even though I’ve got the same rules in place for both.
Hello.
just to be sure: you are trying to add a new subnet to an existing tunnel ?
-->  Like I say I already have one working tunnel but the second one
Or are you trying to set up a completely new, second tunnel ?
A second tunnel over the same VPN.
try and delete the access list:
--> no crypto map SS-BLOXHAM-VPN-MAP 50 match address vpn-ibm-blx-to-spbaas
--> no access-list vpn-ibm-blx-to-spbaas extended permit ip 10.20.30.0 255.255.255.0 10.164.255.0 255.255.255.192
--> no access-list vpn-ibm-blx-to-spbaas extended permit ip 10.20.30.0 255.255.255.0 10.164.76.0 255.255.255.240
and the add it with line numbers:
--> access-list vpn-ibm-blx-to-spbaas extended line 1 permit ip 10.20.30.0 255.255.255.0 10.164.255.0 255.255.255.192
--> access-list vpn-ibm-blx-to-spbaas extended line 2 permit ip 10.20.30.0 255.255.255.0 10.164.76.0 255.255.255.240
--> crypto map SS-BLOXHAM-VPN-MAP 50 match address vpn-ibm-blx-to-spbaas
