ASA 5520 boot problem
argagan01
ASA5520 has boot problem, it always stuck at booting process, with no response.
I have tried updating image file using ROMMON but it always fails on Checksum verification on install image failed. tried with different files but no success..
Any suggestion, at present no image file on ASA..
9 Replies 9
Hi ,
 Can you paste me the error message of your console window . Hope you are following correct sequence as given below
http://www.cisco.com/c/en/us/td/docs/security/asa/asa80/configuration/guide/conf_gd/trouble.html
Using the ROM Monitor to Load a Software Image
Sandy
Received 27260928 bytes
Launching TFTP Image...
Cisco Security Appliance admin loader (3.0) #0: Fri Oct 26 16:36:37 PDT 2012
sumval(0xa627) chksum(0x0   )md5(0x9aefcf57 0x1c333de8 0x200043bf 0x98347461)
md5(0x394b088f 0x97e5c6d2 0x2f86214a 0xd0009fa3)
ÿhecksum verification on install image failed.
Booting system, please wait...
CISCO SYSTEMS
Embedded BIOS Version 1.0(11)5 08/28/08 15:11:51.82
Low Memory: 631 KB
High Memory: 2048 MB
PCI Device Table.
Bus Dev Func VendID DevID Class              Irq
 00  00  00   8086   2578  Host Bridge
 00  01  00   8086   2579  PCI-to-PCI Bridge
 00  03  00   8086   257B  PCI-to-PCI Bridge
 00  1C  00   8086   25AE  PCI-to-PCI Bridge
 00  1D  00   8086   25A9  Serial Bus         11
 00  1D  01   8086   25AA  Serial Bus         10
 00  1D  04   8086   25AB  System
 00  1D  05   8086   25AC  IRQ Controller
 00  1D  07   8086   25AD  Serial Bus         9
 00  1E  00   8086   244E  PCI-to-PCI Bridge
 00  1F  00   8086   25A1  ISA Bridge
 00  1F  02   8086   25A3  IDE Controller     11
 00  1F  03   8086   25A4  Serial Bus         5
 00  1F  05   8086   25A6  Audio              5
 02  01  00   8086   1075  Ethernet           11
 03  01  00   177D   0003  Encrypt/Decrypt    9
 03  02  00   8086   1079  Ethernet           9
 03  02  01   8086   1079  Ethernet           9
 03  03  00   8086   1079  Ethernet           9
 03  03  01   8086   1079  Ethernet           9
 04  02  00   8086   1209  Ethernet           11
 04  03  00   8086   1209  Ethernet           5
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(11)5) #0: Thu Aug 28 15:23:50 PDT 2008
Platform ASA5520
Use BREAK or ESC to interrupt boot.
Use SPACE to begin boot immediately.
Boot interrupted.
All process followed are correct
ADDRESS=
SERVER=       No gateway as both machine are connected through cross over
PORT=
IMAGE=
tftp
after this as you will notice, it will start copying file but at end when its time to load new image file, it give checksum error.
Steps already tried:
Tried using different TFTP server (tftpd64 & Solar Winds)
tried using multiple image files
Doing a manual MD5 checksum while downloading the image file.. Files downloaded are perfect.
Hi ,
 I am suspecting issue with your image , may be corrupted , can you download your image again from Cisco portal and upload again to asa appliance .
Sandy
i have tried multiple imaged downloaded from cisco only..847,843,901,903 etc.. but all has same problem.
I have checked checksum with cisco & all are correct...
Can you try formatting your flash memory once
To erase the file system, enter the erase command, which overwrites all files and erases the file system, including hidden system files.
rommon #1> erase disk0: | disk1: | flash:]
Still the same
Hi ,
 Kindly raise Cisco TAC or RMA for Hardware replacement
Sandy
argagan01
Hello Guys,
Any suggestions... I am stuck as ASA isn't accepting any image.
Received 24809472 bytes
Cisco Security Appliance admin loader (3.0) #0: Fri Aug 30 19:48:50 PDT 2013
sumval(0xf09 ) chksum(0x0   )
SHA-512(0xc7f5c601 0xd1edede5 0x6ed553e0 0xdc1c8ea6 0x8f58c580 0x8a4ef6e9 0xf2d33874 0x9886d5ab 0xe5c5cf7d 0x79ca9455 0x17d269f5 0x529d9871 0x51444bcc 0x32e936f8 0xe17ab6ad 0x6739889f)
SHA-512(0xbdf886bf 0xe87afe34 0xf255185b 0x3b87c511 0xa4809089 0x576eb3a9 0xbf7345c3 0xe0ae51d0 0xf0ab015d 0x1b106bc5 0xd8466cae 0x888ebdd2 0x2293280f 0x3228ff11 0x46506a02 0xb3e4c36f)
CISCO SYSTEMS
Low Memory: 631 KB
PCI Device Table.
Platform ASA5520
Boot interrupted.
