ASA 5520 to 5505 ipsec tunnel help
How to configure a ipsec tunnel between a Cisco ASA 5520 and a Cisco ASA 5505?
============================---------------------------remoteasa172-------------------------------=================================
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
: Hardware:   ASA5520, 2048 MB RAM, CPU Pentium 4 Celeron 2000 MHz
: ASA Version 9.1(7)32
interface GigabitEthernet0/0
 nameif outside
 security-level 0
 ip address 192.168.168.232 255.255.255.0
interface GigabitEthernet0/1
 nameif inside
 security-level 100
 ip address 192.168.172.1 255.255.255.0
access-list OUTSIDE-IN extended permit ip any any log
access-list OUTSIDE-IN extended permit icmp any any log
access-list OUTSIDE-IN extended permit tcp any any log
access-list OUTSIDE-OUT extended permit ip any any log
access-list OUTSIDE-OUT extended permit icmp any any log
access-list OUTSIDE-OUT extended permit tcp any any log
access-list INSIDE-IN extended permit ip any any log
access-list INSIDE-IN extended permit icmp any any log
access-list INSIDE-IN extended permit tcp any any log
access-list INSIDE-OUT extended permit ip any any log
access-list INSIDE-OUT extended permit icmp any any log
access-list INSIDE-OUT extended permit tcp any any log
access-list LAN_Traffic extended permit ip 182.168.172.0 255.255.255.0 192.168.180.0 255.255.255.0 log
nat (inside,outside) after-auto source dynamic any interface
access-group OUTSIDE-IN in interface outside
access-group OUTSIDE-OUT out interface outside
access-group INSIDE-IN in interface inside
access-group INSIDE-OUT out interface inside
route outside 0.0.0.0 0.0.0.0 192.168.168.1 1
route inside 192.168.180.0 255.255.255.0 192.168.168.240 1
crypto ipsec ikev1 transform-set TS esp-aes-256 esp-sha-hmac
crypto map CMAP 80 match address LAN_Traffic
crypto map CMAP 80 set peer 192.168.168.240
crypto map CMAP 80 set ikev1 transform-set TS
crypto map enable interface outside
crypto ikev1 enable outside
crypto ikev1 policy 1
 authentication pre-share
 encryption aes
 hash sha
 group 2
 lifetime 86400
dhcpd dns 192.168.168.1
dhcpd lease 3000
dhcpd ping_timeout 20
dhcpd domain mydomain.com
dhcpd option 3 ip 192.168.172.1
dhcpd option 2 ascii dhcpd_option_2_ascii_examplestring_HERE
dhcpd address 192.168.172.3-192.168.172.63 inside
dhcpd enable inside
tunnel-group 192.168.168.240 type ipsec-l2l
tunnel-group 192.168.168.240 ipsec-attributes
 ikev1 pre-shared-key *****
remoteasa172#
============================---------------------------remoteasa180-------------------------------=================================
remoteasa180#
remoteasa180#
remoteasa180#
remoteasa180#
remoteasa180#
remoteasa180#
: Hardware:   ASA5505, 512 MB RAM, CPU Geode 500 MHz
: ASA Version 9.2(4)5
interface Ethernet0/0
 description OUTSIDE_200
 switchport access vlan 200
interface Ethernet0/1
 description INSIDE_180
 switchport access vlan 180
interface Vlan180
 nameif inside
 security-level 100
 ip address 192.168.180.1 255.255.255.0
interface Vlan200
 nameif outside
 security-level 0
 ip address 192.168.168.240 255.255.255.0
access-list LAN_Traffic extended permit ip 192.168.180.0 255.255.255.0 192.168.172.0 255.255.255.0 log
route inside 192.168.172.0 255.255.255.0 192.168.168.232 1
crypto ipsec security-association pmtu-aging infinite
crypto map CMAP 72 match address LAN_Traffic
crypto map CMAP 72 set pfs
crypto map CMAP 72 set peer 192.168.168.232
crypto map CMAP 72 set ikev1 transform-set TS
crypto map CMAP interface outside
 encryption aes
 hash sha
 group 2
 lifetime 86400
dhcpd domain myudomain.com
dhcpd auto_config outside
dhcpd option 3 ip 192.168.180.1
dhcpd address 192.168.180.3-192.168.180.63 inside
dhcpd enable inside
tunnel-group 192.168.168.232 type ipsec-l2l
tunnel-group 192.168.168.232 ipsec-attributes
remoteasa180#
Before we look for more issues on the ASA can you verify whether that PC might have a firewall that is denying the ping?
If the ipsec sa is showing two way traffic I am pretty confident that the issue is not the vpn.
I believe that one thing that was impacting your testing was trying to ping the ASA inside interface from the remote peer. The ASA as a security feature does not allow that kind of access. Here is a link that has some discussion about that. I hope you find it helpful.
https://community.cisco.com/t5/firewalls/can-t-ping-inside-interfaces-on-asa-from-switch/td-p/2711701
Rick
Rick
100 Replies 100
I have made some changes/additions to your configs (marked in bold), try these and see if the VPN comes up:
nameif outside
security-level 0
nameif inside
security-level 100
access-list LAN_Traffic extended permit ip object 192.168.172.0_24 192.168.180.0_24
nat (inside,outside) 1 source static 192.168.172.0_24 192.168.172.0_24 destination static
192.168.180.0_24 192.168.180.0_24 no-proxy-arp route-lookup
object network 192.168.172.0_24
subnet 192.168.172.0 255.255.255.0
object network 192.168.180.0_24
subnet 192.168.180.0 255.255.255.0
crypto map CMAP 80 set pfs
encryption aes
hash sha
group 2
lifetime 86400
dhcpd lease 3000
dhcpd enable inside
remoteasa172#
remoteasa180#
remoteasa180#
remoteasa180#
remoteasa180#
remoteasa180#
remoteasa180#
interface Vlan180
nameif inside
security-level 100
interface Vlan200
nameif outside
security-level 0
access-list LAN_Traffic extended permit ip object 192.168.180.0_24 192.168.172.0_24
nat (inside,outside) 1 source static 192.168.180.0_24 192.168.180.0_24 destination static
192.168.172.0_24 192.168.172.0_24 no-proxy-arp route-lookup
encryption aes
hash sha
group 2
lifetime 86400
dhcpd enable inside
Hi Georg, Thank you for answering. I implemented the changes that you suggested but the tunnel still does not come up....  And I can't find out what is going on.
-----------------================ remoteasa172 ===============---------------------
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
nameif outside
security-level 0
nameif inside
security-level 100
access-list LAN_Traffic extended permit ip object 192.168.172.0_24 object 192.168.180.0_24 log
nat (inside,outside) source static 192.168.172.0_24 192.168.172.0_24 destination static 192.168.180.0_24 192.168.180.0_24 no-proxy-arp route-lookup
crypto ca trustpool policy
encryption aes
hash sha
group 2
lifetime 86400
remoteasa172#
remoteasa172#
remoteasa172#
-----------------================ remoteasa180 ===============---------------------
remoteasa180#
remoteasa180#
remoteasa180#
remoteasa180#
ASA Version 9.2(4)5
interface Vlan180
nameif inside
security-level 100
interface Vlan200
nameif outside
security-level 0
access-list LAN_Traffic extended permit ip object 192.168.180.0_24 object 192.168.172.0_24
nat (inside,outside) source static 192.168.180.0_24 192.168.180.0_24 destination static 192.168.172.0_24 192.168.172.0_24 no-proxy-arp route-lookup
encryption aes
hash sha
group 2
lifetime 86400
remoteasa180#
remoteasa180#
remoteasa180#
remoteasa180#
can you post the full configs of both ASAs ?  I am not sure about the inside routes, through which interface(s) are the ASAs connected ?
Complete config added at end of conversation
which interface is the other ASA connected to (what is the outgoing interface) ?
Sorry, I'd saved a running to flash: and reloaded it. Apparently it kept some of the configuration that I was messing with and mixed them together. I think that I've straightened it out. I guess that I need to do a wr erase to bring in a saved configuration.
Outside interfaces are gi0/0
remoteasa172# ping 192.168.168.240
Sending 5, 100-byte ICMP Echos to 192.168.168.240, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/10 ms
remoteasa172#
remoteasa180# ping 192.168.168.232
Sending 5, 100-byte ICMP Echos to 192.168.168.232, timeout is 2 seconds:
remoteasa180#
remoteasa172# sh route
Gateway of last resort is 192.168.168.1 to network 0.0.0.0
S 192.168.180.0 255.255.255.0 [1/0] via 192.168.168.240, inside
C 192.168.172.0 255.255.255.0 is directly connected, inside
C 10.10.10.0 255.255.255.224 is directly connected, mngt
C 192.168.168.0 255.255.255.0 is directly connected, outside
S* 0.0.0.0 0.0.0.0 [1/0] via 192.168.168.1, outside
remoteasa172#
remoteasa180# sh route
L 192.168.168.240 255.255.255.255 is directly connected, outside
S 192.168.172.0 255.255.255.0 [1/0] via 192.168.168.232, inside
C 192.168.180.0 255.255.255.0 is directly connected, inside
L 192.168.180.1 255.255.255.255 is directly connected, inside
so the current running config is working now ? The NAT statements were missing, and in your original post, the access-list had a typo (182 instead of 192)...
Good luck...
Not working.  The nat always worked but I can't get the ipsec tunnel up.  I'll just remove NAT and dhcp to try to clarify the configuration.  I got messed up by copy flash:saved_running-config running-config :-(  It mushed everything up together UGGGG
post the running configs again...
To repeat what was asked earlier, to which interface is the other ASA connected ? Your remote network is routed through the inside, is that right ?
This route is still in the config
Note that the next hop is on the outside interface. So no this route is not correct.
Rick
Rick
Cleaned up the configuration and I've only left the tunnel.  Thank you for your help
----------------================ remoteasa172# ===============--------------------
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172# sh run
: Saved
: Serial Number: JMX1519L0A3
hostname remoteasa172
domain-name mydomain.com
enable password N7HlIItY8AVJppkQ encrypted
names
nameif outside
security-level 0
nameif inside
security-level 100
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
nameif mngt
security-level 0
ip address 10.10.10.12 255.255.255.224
interface Management0/0
management-only
nameif management
security-level 100
ftp mode passive
dns server-group DefaultDNS
pager lines 24
logging enable
logging timestamp
logging monitor debugging
logging buffered informational
logging asdm informational
mtu management 1500
mtu outside 1500
mtu inside 1500
mtu mngt 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any inside
icmp permit any mngt
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
encryption aes
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh stricthostkeycheck
ssh 192.168.168.0 255.255.255.0 outside
ssh timeout 5
ssh key-exchange group dh-group14-sha1
console timeout 0
dhcpd lease 3000
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username cisco password 73ozQQQ.JMBHDyQz encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:35118980fabe00f273e38b57bdc97600
: end
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
--------------================= remoteasa180# ==============-----------------------
remoteasa180#
remoteasa180#
remoteasa180#
remoteasa180#
remoteasa180# sh run
: Saved
: Serial Number: JMX1650Z14E
ASA Version 9.2(4)5
hostname remoteasa180
domain-name mydomian.com
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
shutdown
no nameif
security-level 100
interface Vlan2
shutdown
no nameif
security-level 0
ip address dhcp setroute
interface Vlan180
nameif inside
security-level 100
interface Vlan200
nameif outside
security-level 0
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
pager lines 24
logging enable
logging timestamp
mtu inside 1500
mtu outside 1500
no failover
arp timeout 14400
http server enable
encryption aes
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 192.168.180.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
Cryptochecksum:ce6955c2037e96a0f85c11af532904b5
: end
remoteasa180#
remoteasa180#
remoteasa180#
remoteasa180#
use the configs below and just remove the route inside statements on both ASAs. I don't think your ASA is connected to a LAN interface, is tha right ?
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa172#
nameif outside
security-level 0
nameif inside
security-level 100
--> route inside 192.168.180.0 255.255.255.0 192.168.168.240 1
encryption aes
hash sha
group 2
lifetime 86400
remoteasa172#
remoteasa172#
remoteasa172#
remoteasa180#
remoteasa180#
remoteasa180#
remoteasa180#
ASA Version 9.2(4)5
interface Vlan180
nameif inside
security-level 100
interface Vlan200
nameif outside
security-level 0
--> no route inside 192.168.172.0 255.255.255.0 192.168.168.232 1
encryption aes
hash sha
group 2
lifetime 86400
remoteasa180#
This is in the config of the 5520
Note which interface is specified
Rick
Rick
OH
remoteasa172# sh run | i route
route outside 192.168.180.0 255.255.255.0 192.168.168.240 1
remoteasa172#
remoteasa172# sh crypto isakmp sa
There are no IKEv1 SAs
There are no IKEv2 SAs
remoteasa172# sh crypto ikev1 sa
remoteasa172# sh crypto ipsec sa
There are no ipsec sas
remoteasa172#
remoteasa180# sh run | i route
route outside 192.168.172.0 255.255.255.0 192.168.168.232 1
remoteasa180# sh crypto isakmp sa
remoteasa180# sh crypto ikev1 sa
remoteasa180# sh crypto ipsec sa
remoteasa180#
