ASA Config -- extra entries added automatically after config loads?????
djgriggs1
asa5516 added the following entries to the running-config ( how , where from ) this was not part of the config...
This should not be there it was not part of the config template that was created.
 policy-map type inspect dns migrated_dns_map_1
  parameters
    message-length maximum client auto
    message-length maximum 512
    no tcp-inspection
 policy-map global_policy
   inspect ftp
   inspect tftp
 following lines were entered by asa
      policy-map type inspedct dns migrated_dns_map_2
         parameters
           no tcp-inspection
That was probably part of the factory-default config. You have to remove/modify it based on your needs.
Karsten,
I am loading my Config to startup-Config. Which seems to work on the ads 5515 with no issue.
so I would not think that it would add in with my loaded config
After further research it appears that the ads is setting a default policy even after I load a config. Working on how to prevent this and load what is in the config file only
