Asa firewall configuration
chrispin
I have done all the necessary configuration on My firewall (access list,  nat, default route) but I still cant ping to the other network (out side)
13 Replies 13
post the full running configuration of your ASA...
My inside network 192.168.1.0
My outside network 10.10.10.0(outside of the firewall)
asa- in g1/1
nameif -inside
   Security -level 100%
 Asa(config)# route outside 10.10.10.2 255.255.255.0 10.10.10.1
Icmp configuration =(access-list oti extended permit icmp any any echo
=access-list oti extended permit icmp any any echo-reply
=access-list oti extended permit icmp any any unreachable)
Nat configuration=( object network) # host 192.168.0.0
Asa(Config-network-object) # Nat ( inside,  outside) dynamic interface
That is my configuration sir
--> Asa(config)# route outside 10.10.10.2 255.255.255.0 10.10.10.1
Is this a 'real' ASA or a Packet Tracer project ?
Packet tracer project
that could explain it, the Packet Tracer ASA has a few quirks. Post the zipped project (.pkt) file...
Hello
See attached working PT file -
Kind Regards
Paul
I am not sure what file you saved, but the one you sent had a lot of errors (missing and wrong static routes on the routers, the access list on the firewall was not applied, the global policy had no ICMP o=inspection, the NAT had only one non-existing host).
Attached the working file.
OK I'm working on it after which I am sending it
Hello please i need a favor would you do that configuration and send it to me as my guide
Nat.
Access list
All the necessary configuration on Cisco firewall to enable outside Network routing please
here are the configs for the ASA and both routers:
ciscoasa#sh run
: Saved
ASA Version 9.6(1)
hostname ciscoasa
names
interface GigabitEthernet1/1
nameif inside
security-level 100
interface GigabitEthernet1/2
nameif outside
security-level 0
ip address 10.10.10.2 255.255.255.0
interface GigabitEthernet1/3
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/4
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/5
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/6
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/7
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/8
no nameif
no security-level
no ip address
shutdown
interface Management1/1
management-only
no nameif
no security-level
no ip address
shutdown
object network obj_192_168_1_0
subnet 192.168.1.0 255.255.255.0
nat (inside,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 10.10.10.1 1
access-group oti in interface outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect tftp
service-policy global_policy global
telnet timeout 5
ssh timeout 5
ciscoasa#
Router0#sh run
Building configuration...
Current configuration : 773 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router0
ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
ip address 10.10.10.1 255.0.0.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet1/0
bandwidth 5000
ip address 2.2.2.2 255.0.0.0
interface Vlan1
no ip address
shutdown
ip classless
ip route 8.0.0.0 255.0.0.0 2.2.2.1
ip route 192.168.1.0 255.255.255.0 10.10.10.2
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Router1#sh run
Current configuration : 672 bytes
version 12.4
hostname Router1
ip cef
no ipv6 cef
bandwidth 5000
ip address 8.8.8.1 255.0.0.0
duplex auto
speed auto
ip address 5.5.5.1 255.0.0.0
duplex auto
speed auto
ip address 2.2.2.1 255.0.0.0
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 2.2.2.2
line con 0
line aux 0
line vty 0 4
login
end
Hello
Can you post the current running configuration of the ASA, in the interim please see attached as a possible default configuration of a ASA providing Inter-Vlan Routing,NAT and ICMP (ping)
kind regards
Paul
Kind Regards
Paul
icmp inspection need to make ASA forward ICMP traffic.
