ASA -> ROUTER -> LAN - syslog question
crisponions
Hello, I am running the following config
cloud -> ASA -> ROUTER -> LAN,
I am doing NAT/PAT on the router instead of the ASA because I am bumping up against my 10 user license.
Everything is working fine, but I am having an issue trying to get the asa to log to a syslog server inside the LAN.
I have the pointed the ASA logging host to the outside IP of the router, and set up a static nat statement on the router  to forward traffic on port 514 to the internal syslog server.
It isn't working, from what I am showing the ASA isn't even trying to log to the router (no hits for the nat translation are shown in the router)
I am going about this wrong, any suggestions?
sean_evershed
Level 7
Level 7
Do you have a spare interface on your ASA that you could configure and connect a test PC running something like Kiwi syslog to see if it will receive the syslog messages? If that works then maybe there is a problem with the NAT config.
- There are no ACLs on your LAN that could be blocking traffic?
- What is the syslog software that you are using? Is it working successfully now for other Cisco devices in your network?
- You could try configuring Netflow on your router to see if it is receiving any syslog traffic from the ASA.
Please remember to rate all posts that are helpful.
5 Replies 5
hobbe
Level 7
Level 7
Have you enabled logging ?
have you set the right logging host ?
have you set that whatever you want to be logged ?
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805a2e04.shtml
Good luck
Collin Clark
Can you post your configs?
sean_evershed
Level 7
Level 7
Thanks for the tips.  It turned out the be the logging server.  Tested having the router log to it
and it failed too.  Changed some configs on the syslog server and all is working as expected.
Thanks for the rating and thanks for the feedback. Good to see it was a simple fix.
Cheers
Sean
