ASA site to site NAT
Willb3
Hi All,
Going to set up a site to site on my ASA, however I will need to use the public addresses rather than private addresses in the encryption domain. The question I have is that if I already have static NAT configured for the IP's do I need a nat statement for the VPN like so ?
nat (any,outside) source static LOCAL LOCAL destination static REMOTE REMOTE no-proxy-arp route-lookup
Jon Marshall
You shouldn't need another NAT statement then.
You usually see one simply because for the VPN you are using the private IPs but as you are using the public IPs and you already have NAT setup no need as far as I can see.
Jon
