ASA
Ketan Bheda
Can we use ASA after router from down link to up link direction.
Is it necessary to use it after the core switches.
6 Replies 6
the ASA is supposed to protect your network, so you should place it as close to the network edge (which means, as close to the outside connection) of your network. That is the (very) general idea. You can obviously place a router in front of the ASA. What is your network supposed to look like ?
Hi Georg,
Please find the image of infrastructure.
In the infrastructure given in the image i have configured HSRP for a redundanency network.
I have tried configuring the ASA but my ASA was able to ping only to its neighboring routers but not user end pc's.
Also after configuring the ASA box Users cannot reach to the internet 4.4.4.4 and 8.8.8.8.
Note: Please consider that all the users are connected with the switch.
I have also applied an ACL's on both standby and active routers where only VLAN 40 (the group of users connected to MUM-DSW04) are allow to communicate with remote location (Delhi).
Can you please suggest me the set of rules to follow while configuring ASA. If you would help me in commands also will do .
Thank you
Hello
Can you post a topology please
res
paul
Kind Regards
Paul
Hi Paul,
Please refer the below reply with commands and Image file.
Thank you!
Please correct me if I understanding wrong, but currently the ASA is isolated from the rest of the network, well. Im not really sure how the infrastructure will be but the first step I suggest is create an any any ACLs just to verify the proper connectivity.
ASA
interface g0/0
nameif OUTSIDE
security-level 0
ip address x.x.x.x x.x.x.x
interface g0/1
nameif INSIDE
security-level 100
ip address y.y.y.y y.y.y.y
ip access-list INSIDE-ACL extended permit icmp any any
ip access-list INSIDE-ACL extended permit icmp any any echo
ip access-list INSIDE-ACL extended permit icmp any any echo-reply
ip access-list INSIDE-ACL extended permit ip any any
ip access-list OUTSIDE-ACL extended permit icmp any any
ip access-list OUTSIDE-ACL extended permit icmp any any echo
ip access-list OUTSIDE-ACL extended permit icmp any any echo-reply
ip access-list OUTSIDE-ACL extended permit ip any any
access-group INSIDE-ACL in interface INSIDE
access-group OUTSIDE-ACL in interface OUTSIDE
route OUTSIDE 0.0.0.0 0.0.0.0 ISP1
route INSIDE <Inside networks> <inside next hop IP>
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
 Current configuration : 4408 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname MUM-RT01-Active
enable secret 5 $1$mERr$iReMtoOFQEl2wyGEfLcyU/
ip dhcp excluded-address 192.168.50.100 192.168.50.200
ip dhcp pool voice
 network 192.168.50.0 255.255.255.0
 default-router 192.168.50.103
 option 150 ip 192.168.50.103
 dns-server 4.4.4.4
ip cef
no ipv6 cef
username ntw1 password 0 support
ip ssh version 2
ip domain-name abc.com
spanning-tree mode pvst
interface Tunnel10
 ip address 172.16.0.1 255.255.0.0
 mtu 1476
 tunnel source FastEthernet0/1
 tunnel destination 192.1.45.5
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0.1
 encapsulation dot1Q 10
 ip address 192.168.10.100 255.255.255.0
 ip access-group nodelhi in
 standby 1 ip 192.168.10.103
 standby 1 priority 250
 standby 1 preempt
interface FastEthernet0/0.2
 encapsulation dot1Q 20
 ip address 192.168.20.100 255.255.255.0
 standby 1 ip 192.168.20.103
 standby 1 priority 200
 standby 1 preempt
interface FastEthernet0/0.3
 encapsulation dot1Q 30
 ip address 192.168.30.100 255.255.255.0
 standby 1 ip 192.168.30.103
 standby 1 priority 244
 standby 1 preempt
interface FastEthernet0/0.4
 encapsulation dot1Q 40
 ip address 192.168.40.100 255.255.255.0
 standby 1 ip 192.168.40.103
 standby 1 priority 254
 standby 1 preempt
interface FastEthernet0/0.5
 encapsulation dot1Q 50
 ip address 192.168.50.100 255.255.255.0
 standby 1 ip 192.168.50.103
 standby 1 preempt
interface FastEthernet0/1
 ip address 192.168.1.2 255.255.255.0
 duplex auto
 speed auto
 standby 1 ip 192.168.1.4
 standby 1 preempt
interface Vlan1
 no ip address
 shutdown
router ospf 1
 log-adjacency-changes
 network 192.168.50.0 0.0.0.255 area 0
 network 172.16.0.0 0.0.255.255 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip flow-export version 9
ip access-list extended nodelhi
 deny ip 192.168.10.0 0.0.0.255 10.10.10.0 0.0.0.255
 deny ip 192.168.10.0 0.0.0.255 10.10.20.0 0.0.0.255
 deny ip 192.168.10.0 0.0.0.255 10.10.30.0 0.0.0.255
 deny ip 192.168.20.0 0.0.0.255 10.10.10.0 0.0.0.255
 deny ip 192.168.20.0 0.0.0.255 10.10.20.0 0.0.0.255
 deny ip 192.168.20.0 0.0.0.255 10.10.30.0 0.0.0.255
 deny ip 192.168.30.0 0.0.0.255 10.10.10.0 0.0.0.255
 deny ip 192.168.30.0 0.0.0.255 10.10.20.0 0.0.0.255
 deny ip 192.168.30.0 0.0.0.255 10.10.30.0 0.0.0.255
 permit ip any any
logging 192.168.40.50
dial-peer voice 100 voip
 destination-pattern 2...
 session target ipv4:172.16.0.2
telephony-service
 max-ephones 16
 max-dn 20
 ip source-address 192.168.50.103 port 2000
ephone-dn 1
 number 1101
ephone-dn 2
 number 1102
ephone-dn 3
 number 1103
ephone-dn 4
 number 1201
ephone-dn 5
 number 1202
ephone-dn 6
 number 1203
ephone-dn 7
 number 1301
ephone-dn 8
 number 1302
ephone-dn 9
 number 1303
ephone-dn 10
 number 1401
ephone-dn 11
 number 1402
ephone-dn 12
 number 1403
ephone 1
 device-security-mode none
 mac-address 000C.CFB9.6397
 type 7960
 button 1:1
ephone 2
 mac-address 0090.0CA2.8138
 type 7960
 button 1:2
ephone 3
 mac-address 000A.F3DC.A6BA
 type 7960
 button 1:3
ephone 4
 mac-address 00E0.A39A.7D6A
 type 7960
 button 1:4
ephone 5
 mac-address 0001.641B.E859
 type 7960
 button 1:5
ephone 6
 mac-address 000A.F398.3348
 type 7960
 button 1:6
ephone 7
 mac-address 0030.F225.4282
 type 7960
 button 1:7
ephone 8
 mac-address 0030.F296.A783
 type 7960
 button 1:8
ephone 9
 mac-address 0060.3EC5.1B7D
 type 7960
 button 1:9
ephone 10
 mac-address 0090.2BAD.0487
 type 7960
 button 1:10
ephone 11
 mac-address 000C.85C9.631E
 type 7960
 button 1:11
ephone 12
 mac-address 0003.E40C.AAA9
 type 7960
 button 1:12
ephone 13
 mac-address 0002.16EB.207B
line con 0
 password cisco
 login
line aux 0
line vty 0 4
 login local
ntp server 192.168.40.50 key 1234
end
Current configuration : 4365 bytes
version 12.4
hostname MUM-RT01-Standby
ip dhcp pool voice
 dns-server 4.4.4.4
ip cef
no ipv6 cef
ip ssh version 2
interface Tunnel10
 ip address 172.16.0.3 255.255.0.0
 mtu 1476
 tunnel destination 192.1.54.5
 no ip address
 duplex auto
 speed auto
 ip address 192.168.10.101 255.255.255.0
 standby 1 preempt
 ip address 192.168.20.101 255.255.255.0
 standby 1 preempt
 ip address 192.168.30.101 255.255.255.0
 standby 1 preempt
 ip address 192.168.40.101 255.255.255.0
 standby 1 preempt
 ip address 192.168.50.101 255.255.255.0
 standby 1 preempt
 ip address 192.168.1.3 255.255.255.0
 duplex auto
 speed auto
 standby 1 preempt
interface Serial0/2/0
 no ip address
 clock rate 2000000
 shutdown
interface Serial0/2/1
 no ip address
 clock rate 2000000
interface Vlan1
 no ip address
 shutdown
router ospf 1
ip classless
 permit ip any any
 session target ipv4:172.16.0.4
telephony-service
 max-ephones 16
 max-dn 20
ephone-dn 1
 number 1101
ephone-dn 2
 number 1102
ephone-dn 3
 number 1103
ephone-dn 4
 number 1201
ephone-dn 5
 number 1202
ephone-dn 6
 number 1203
ephone-dn 7
 number 1301
ephone-dn 8
 number 1302
ephone-dn 9
 number 1303
ephone-dn 10
 number 1401
ephone-dn 11
 number 1402
ephone-dn 12
 number 1403
ephone 1
 type 7960
 button 1:1
ephone 2
 type 7960
 button 1:2
ephone 3
 type 7960
 button 1:3
ephone 4
 type 7960
 button 1:4
ephone 5
 type 7960
 button 1:5
ephone 6
 type 7960
 button 1:6
ephone 7
 type 7960
 button 1:7
ephone 8
 type 7960
 button 1:8
ephone 9
 type 7960
 button 1:9
ephone 10
 type 7960
 button 1:10
ephone 11
 type 7960
 button 1:11
ephone 12
 type 7960
 button 1:12
ephone 13
line con 0
 password cisco
 login
line aux 0
line vty 0 4
 login local
end
Hi Julio,
Please find the attachments.
The image is the half of the infrastructure and initially I am working on entire location of Mumbai to get the access to internet using ASA.
Please find the codes I have written and I found that my ASA can reached its neighbor routers (HSRP and ISP Routers) but my none of these switches is able to reach to ASA and through ASA.
Also can you please let me know the meaning of the command:
I did tracert from the user end and found that it got stuck up at 192.168.1.1 ie inside interface but cant get through that.
Also when I try to reach from Server 4.4.4.4 to one of my user its shows "request time out". When I did tracert from the server to reached my user then it get stuck up at 192.1.23.2.
From the above I conclude it turn out to be as follows:
-ASA Can ping neighbors and vice versa.
-Users cant get a access to internet 4.4.4.4 and 8.8.8.8 (it shows request time out).
-Internet server can only be reachable till 192.1.23.2 ie ISPR1.
-While doing tracert users can only reach upto 192.168.1.1 (i.e ASA)newinfra.PNG
