ASA5520 v8.2 to v9.1 Dynamic NAT help
moored
I need to allow internal hosts that do not have a public static IP to be able to communicate with internet hosts, ie download software from the Internet
My public address range is 122.252.14.240/28
My internal IP address range is 192.168.100.0/24
The ASA5520 is on 192.168.100.254
This is the nat rule I have in an older ASA5510 software version
ASA Version 8.2(1)
global (outside1) 1 interface
nat (Inside1) 1 INT_Net 255.255.255.0
access-group outside in interface outside1
route outside1 0.0.0.0 0.0.0.0 122.252.14.241 1
I am commissioning an ASA5520 The ASA Version is 9.1(4)
When I run: global (outside1) 1 interface
I am getting
ERROR: This syntax of nat command has been deprecated.
can somebody help me re write this rule.
Jon Marshall
David
You may want to look at the document link at the bottom which gives all the examples of how to configure 8.3 NAT onwards. You can download the pictures section separately and it gives specific examples. When you configure with the new NAT you need to configure it all in one because of the way it groups it together in the configuration.
What i mean by this is that you should not reference your existing INT_Net as it would not be grouped with the rest of the specific NAT configuration.
There are basically two ways to configure what you are trying to do but you should read the document because depending on the other NAT on your ASA you might need to use one or the other ie. section 1 dynamic PAT or section 3 dynamic PAT.
Section 1
object network
network 192.168.100.0 255.255.255.0
nat (inside,outside) dynamic interface
Section 3
object-group network
network-object 192.168.100.0 255.255.255.0
nat (inside,outside) after-auto source dynamic interface
either may be alright for you but worth reading the document to get an idea of how it all works -
https://supportforums.cisco.com/docs/DOC-31116
Jon
Thanks for the reply, I tried option 1 to start with and it seems to work ok.
I made a small change as I got an error:
changes to:
subnet 192.168.100.0 255.255.255.0
