ASDM IOS upgrade in ASA
Rupesh Kashyap
I have to update ASDM IOS on ASA 5540. Please guide how to do it as this ASA is in the production?
Is it mandatory to restart the ASA?
5 Replies 5
Ganesh Hariharan
Check out the below link to upgrade ASDM in firewall hope that help
http://www.cisco.com/en/US/customer/products/hw/vpndevc/ps2030/products_tech_note09186a00804708d8.shtml#t8
If helpful do rate the post !!
Ganesh.H
Thanks for replying. The problem is, we have configured Multi-Context on this & we are not using any IP on System Context where Disk0 is activated.
How can I transfer the image from Console? Can I use Xmodem ?
As you are upgarding the existing ASDM version which is running in firewall so what i would suggest login into firewall via ASDM and then browse for new ios image in your local pc and upload,check out the below link hope that help
http://www.cisco.com/en/US/docs/security/asa/asa70/asdm50/release/notes/asdmrn507.html#wp311218
Ganesh.H
The problem is , I do NOT have any ASDM IOS in that, so I am unable to open ASDM?
Please help if I can transfer the ASDM IOS from Console?
Once you have downloaded this software, upload it to the PIX Security Appliance using the same method you would use to upgrade the IOS® on the router (TFTP, XModem, and so forth). Once the ASDM software is located in Flash memory on the PIX Security Appliance, use the global configuration command asdm image flash:/ where is the filename of the ASDM software
Hope to Help
Ganesh.H
