Ask the Expert: Architecture and Troubleshooting Cisco ASR 1000 Series Aggregation Services Routers
ciscomoderator
Community Manager
Community Manager
Architecture and troubleshooting Cisco ASR 1000 Series Aggregation Services Routers with Hitesh KumarWith Hitesh Kumar
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn and ask questions about architecture and packet capture on Cisco ASR 1000 Series Aggregation Services Routers with Cisco expert Hitesh Kumar. Learn about the Cisco ASR 1000 Series--a class of mid-range routers offering convergence of network services on highly scalable routing platforms. The Cisco ASR 1000 Series delivers superior resiliency with intelligent services and modularity to meet the long-term needs of both enterprise and service provider applications.
Hitesh Kumar is a customer support engineer in the High Touch Technical Services team at Cisco specializing in routing protocols. He has been supporting major service providers and enterprise customers in routing, Multiprotocol Label Switching (MPLS), Multicast, and Layer 2 Virtual Private Network (L2VPN) issues on Routing platforms for more than three years. He has more than six years of experience in the IT industry and holds a CCIE certification in Service (#38757).
Remember to use the rating system to let Hitesh know if you have received an adequate response.
Hitesh might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the Network Infrastructure > WAN, Routing and Switching subcommunity shortly after the event.This event lasts through Tuesday April 26, 2013. Visit this forum often to view responses to your questions and the questions of other Cisco Support Community members.
2 Accepted Solutions
Hi Imran
    On ASR1k IOS  and other software on the router can be upgraded using the In Service  Software Upgrade (ISSU) feature in the standby IOS process, thereby  allowing the network to remain active during the software upgrade.
   The Cisco ASR 1001, ASR1002-F, ASR 1002, ASR 1002-X, and Cisco ASR 1004  support dual Cisco IOS Software redundancy with a single route  processor configuration. This feature is not supported on the Cisco ASR  1006 or Cisco ASR 1013.
  The  Cisco ASR 1006/1013 supports 1+1 active and standby redundancy in dual  RP and dual ESP configuration. Switchover of the route processor does  not result in switchover of the ESP, and switchover of the ESP does not  result in switchover of the route processor.
Hitesh
Hi Bilal
    Good to hear that the issue was resolved. Since IGMP snooping is enabled in your network so we need a querier. Using this command it designated ASR's as querier.
Hitesh
33 Replies 33
Emad.arezoomand
HELLO
i bought a linskey E1200 some days back and i tried to fix it myself , it was my first time to fix a router myself and i want it for my home only . ive fixed the internet cable and the cable from router to my PC and i went trough the steps over the CD provided in the pack . but and the end  of the setup there is an error coming that the router cant connect to internet .
i have asked my isp provider and they took the router to set up the settings and when they brought it back they told that its ok now and it was working with them but ive tired it over my pc and 2 other laptops (direct cable) to connect to internet via router but its not wrking . the cable coming to me is a pppoe and i have a user name pass over it , ive tried also to go to this 192.168.1.1 ip and choose the pppoe and insert my username and pass there but after this my network sahring shows that i have access to internet and at the status i can see it is connected and ip of the network has been stablished but how much ive tried i couldnt brows any page its not loading any page just like to conction is there .
i want to conect my internet to my router to have both internet over my pc wich has no wifi and to have wifi all over my home , would u pls help me to fix this issue ?
regards
Hi Emad
     You have selected wrong forum, as this forum is made for queries on ASR1k platform. If you are facing any issue with
linskey device I would advise to check with them.
Hitesh
Vinit Jain
Hello Hitesh
As far as i understand there are two RP's on ASR1k. RP1 & RP2. Could you please share the architectural differences between them.
--Vinit
Hi Vinit
     Below are the differences between RP1 and RP2:
CPU
- RP1 has Single 1.5 GHz PowerPC CPU while RP2 has Dual 2.66 GHz Intel x86
DRAM
- RP1 supports 4 GB while RP2 supports up to 8 GB of field-replaceable memory
Bulk Storage hard Disk
- RP1 has Internal 40 GB hard-disk while RP2 has Front-mounted 80 GB hard-disk
Bootflash/NVRAM
- RP1 supports 512 MB eUSB RP2 supports 2 GB eUSB
The Cisco ASR1000-RP1 and Cisco ASR1000-RP2 cannot exist in the same chassis.
   Please let me know in case of any other queries.
Hitesh
Hi Hitesh,
I have some questions ,
Q.1 What is the difference between ISR and ASR Routers?
Q.2 Do ASR Routers also have the same IOS as other routers?
Hi Fahad
   By ASR I believe you mean ASR1k. The cisco ASR1k was introduced to facilitate more flexible, efficient, and  high-performance delivery of complex consumer and business services. Below are the main features of ASR1k which are not present in ISR
- Cisco ASR1k has seperate conrol and data planes.
- Cisco ASR1k supports software redundnacy on ASR1001, ASR1002, ASR1002-X, ASR1004 Routers and Hardware redundancy on the Cisco ASR 1006 and 1013 Routers
- Cisco ASR1k supports Modular Cisco IOS XE Software to facilitate In-Service Software Upgrade (ISSU)
- It has a seperate processor ESP to take all the forwarding decisions
- Scalable services embedded in the Cisco QuantumFlow Processor at wire speeds from 2.5 Gbps to 100 Gbps
Below is datasheet (including ISR's) providing performance information:
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
  Refering to your second query Cisco ASR1k runs IOSXE has IOS running as a process with a modern Linux operating system
  IOSXE has been designed to support all the above mentioned featured plus most of the features of IOS.
  Please let me know in case of any query.
Hitesh
Helllo Hitesh, Maybe you could help me.
I'm having troubles with multicast on a network with ASR's that are performing OTV.(mixture of ASR1001 and ASR1002) I just wanted an opinion from someone who is an expert with the ASR1K.
We have two sites, Site A and Site B. They both have Vlan 724 - and is on the overlay interfaces across both sites, on a flat network (no router's or SVI's in this stretched vlan). I know I have configured OTV correctly.
I cannot seem to run multicast within this vlan, on the same LAN. Even within a site (on the same switch that has the vlan) and also site to site, in the same 724 vlan which is extended across sites.
Do you have any idea's why this wouldnt work?
The mrouted ports, all point towards the direction of the ASR, but I can't see on the ASR where it goes from there. There's not meant to be an mrouted port in the first place since there is no multicast router in this vlan.
tia
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hi Bilal
   I am assuming that your unicast is working fine between the sites. Please correct me if I am wrong here. Assuming that your unicast is working fine below are the configuration commands that are required on ASR1k. Please check and verify if they are present in your case.
ip multicast-routing distributed         \ Enables multicast routing
ip igmp snooping querier version 3   \ If ASR is the querier this command enables igmp snooping for multicast data traffic
Please let me know in case of any concerns.
Hitesh
Thanks for your reply Hitesh,
I can verify that ip multicast-routing is enabled. And also that unicast does work.
I have not got ip igmp snooping querier command enabled. Where do I configure this command - under which interface?
The ASR, or any other networking device does not have an interface within this vlan, I have a multicast source and destination within the same vlan on the same switch too (3750). Only layer 2.
ASR01-----4500-----3750
The ASR config:
interface Overlay1
no ip address
otv control-group 239.1.1.1
otv data-group 232.1.1.0/28
otv join-interface Loopback10
service instance 724 ethernet
  encapsulation dot1q 724
  bridge-domain 724
interface GigabitEthernet0/0/2
description ## Trunk to 4506-01 - OTV & ROUTE ## Gi4/10 ##
no ip address
negotiation auto
cdp enable
service instance 8 ethernet
  encapsulation dot1q 8
  bridge-domain 8
  bridge-domain 724
4500:
4506-01#show run int gi4/10
Building configuration...
Current configuration : 166 bytes
interface GigabitEthernet4/10
description ## Trunk to ASR1001-01 ## Gi0/0/2 ##
switchport trunk allowed vlan 8,724
switchport mode trunk
description ## 3750-101 ##
switchport trunk allowed vlan 724
end
4506-1#show ip igmp snooping mrouter
Vlan    ports
724    Gi4/10(dynamic)
3750:
3750-101#show run int gi1/0/1
interface GigabitEthernet1/0/1
description ## 4506-01 ## Gi4/1 ##
end
3750-101#show ip igmp snooping mrouter
Vlan    ports
724    Gi1/0/1(dynamic)
I do not understand why I am seeing this mrouter port on these switches since there is not a routed interface in this vlan. Why is it going towards the ASR?
Thank you for your help.
Hi Bilal
    the command should be in global config mode. I checked on my node and its working. I am running 15.2(2)S. may be you are running old code.
MRIUTIA-R03C-GZ-EG#sh ver
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.2(2)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 26-Mar-12 16:23 by mcpre
IOS XE Version: 03.06.00.S
Cisco IOS-XE software, Copyright (c) 2005-2012 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
MRIUTIA-R03C-GZ-EG uptime is 26 minutes
Uptime for this control processor is 27 minutes
System returned to ROM by reload
System image file is "bootflash:asr1000rp2-adventerprisek9.03.06.00.S.152-2.S.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1004 (RP2) processor with 4238341K/6147K bytes of memory.
Processor board ID FOX1544G2MJ
5 Gigabit Ethernet interfaces
MRIUTIA-R03C-GZ-EG(config)#ip igmp snooping querier
   Can you please elaborate "I have a multicast source and destination within the same vlan on the same switch too (3750)". Does this means that source and destination are not talking to each other ? or do they need to talk via ASR1k?
   Regarding your query that igmp snooping mrouter being shown towards ASR1k, a queries will show itself as an mrouter. Below is the link for your refernce:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008059a9df.shtml#solu2
   Maybe your ASR1k is already acting as a querier and that is the reason for the interface towards ASR1k being displayed. Please check the output of
show ip igmp snooping querier
Hitesh
Sure - I should have explained a little better, on the 3750 I have a multicast source (master) e.g. plugged in on fa1/0/1 and a client on fa1/0/2, on the same vlan - 724 - that wants to join the group, but can't.
The tests I've done have been to test this in a lab environment without ASRs and the multicast works in a flat vlan with a basic switch config. (igmp snooping enabled by default) and there is no mrouted port in that environment. For some reason, I am learning it dynamically when there is no pim or mrouter in this vlan anyway.
This is the output I get from the command.
ASR1001-01#show ip igmp snooping querier
Vlan      IP Address               IGMP Version   Port
ASR1001-01#
I am able to implement the command ip igmp snooping querier, it is available to me.
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.2(2)S, RELEASE SOFTWARE (fc1)
software.
ROM: IOS-XE ROMMON
IH-ASR1001-01 uptime is 8 weeks, 6 days, 20 hours, 49 minutes
Uptime for this control processor is 8 weeks, 6 days, 20 hours, 51 minutes
System returned to ROM by reload at 18:19:04 UTC Sat Feb 16 2013
System restarted at 18:21:51 GMT Sat Feb 16 2013
System image file is "bootflash:asr1001-universalk9.03.06.00.S.152-2.S.bin"
Last reload reason: Reload Command
export@cisco.com.
License Level: advipservices
License Type: Permanent
Next reload license Level: advipservices
cisco ASR1001 (1RU) processor with 1163576K/6147K bytes of memory.
Processor board ID SSI16050CNJ
8 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7741439K bytes of eUSB flash at bootflash:.
Should the query command fix this problem?
Thanks for your help.
Hi Bilal
   Can you implemet the querier command and let me know the results. Also get me the output of
"show ip igmp snooping querier" from ASR and other devices in the lan after implemeting the command.
Hitesh
Hello Hitesh,
This command seemed to work for me! Eventually I had things set up like this:
Client----3750-141-----ASR1002-01----(OTV)----IH-ASR----3750-LOADTEST-101-----Source
I implemented the ip igmp snooping querier command on both ASR's and it seemed to work fine. I could also do this on the same switch.
3750-141#show ip igmp snooping querier
724       192.168.230.1            v2            Po1
ASR1002-01#show ip igmp snooping querier
724       192.168.230.1            v2            Router
IH-ASR1001-01#show ip igmp snooping querier
724       192.168.40.1             v2            Router
3750-LOADTEST-101#show ip igmp snooping querier
724       192.168.40.1             v2            Gi1/0/1
ASR1002-01#show ip igmp snooping mrouter
Vlan    ports
724    Router
IH-ASR1001-01#show ip igmp snooping mrouter
Vlan    ports
724    Router
So what was I missing? What does the querier command do on the ASR in this scenario?
Thank you for your help!
Hi Bilal
Hitesh
