Ask the Expert: Troubleshooting WAN Links Using QoS
ciscomoderator
Community Manager
Community Manager
Read the bioTroubleshooting WAN Links Using QoS
with Sarala Akella
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn how to troubleshoot congestion on WAN links by using QoS and buffering best practices to optimize traffic flow. This includes queueing techniques (like WFQ, CBWFQ, or LLQ,) congestion avoidance (like WRED and CAR) as well as policing and traffic shaping mechanisms. Sarala is a customer support engineer at the Cisco Technical Assistance Center. She currently works in the WAN team where she focuses on various WAN related issues along with QoS issues on various interfaces. Sarala has been with Cisco for 11 years and has worked as a software engineer in the Network Software and Systems Technology Group. She holds a master's degree in computer engineering from Santa Clara University and a master's degree in mathematics from Osmania University, India. She also holds CCIE certification (#29921) in Routing and Switching.
Remember to use the rating system to let Sarala know if you have received an adequate response.
Sarala might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the Network Infrastructure WAN, Routing and Switching discussion forum shortly after the event.   This event lasts through January 13, 2012. Visit this forum often to view responses to your questions and the questions of other community members.
21 Replies 21
Hello Sakella,
That worked perfectly. I may need to tweak the CIR / mincir a bit, but packets are being marked and treated properly.
Thanks!
ymcacisco
I like so many people have been trying to figure out why my QOS policy doesn't give priority to voice.  I have an 1841 router and below is my policy map:
When I look at Strict Priority I have 0\0.
<<< Here is my policy and class map>>>
class-map match-any voice
match access-group 105
match ip dscp ef
policy-map test
class voice
  priority 500
class class-default
policy-map QOS
class class-default
  shape average 50000000
  service-policy test
<<< policy applied to interface>>>>>
interface FastEthernet0/0.80
encapsulation dot1Q 80
ip address 10.2.17.2 255.255.255.0
ip nat outside
ip virtual-reassembly
no snmp trap link-status
service-policy output QOS
Service-policy output: QOS
  Class-map: class-default (match-any)
    266957331 packets, 64135687944 bytes
    5 minute offered rate 3000 bps, drop rate 0 bps
    Match: any
    Traffic Shaping
         Target/Average   Byte   Sustain   Excess    Interval  Increment
           Rate           Limit  bits/int  bits/int  (ms)      (bytes)
       50000000/50000000  312500 1250000   1250000   25        156250
      Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
      Active Depth                         Delayed   Delayed   Active
      -      0         266957344 4006146670 0         0         no
    Service-policy : test
      Class-map: voice (match-any)
        49575139 packets, 10644477652 bytes
        5 minute offered rate 0 bps, drop rate 0 bps
        Match: access-group 105
          49546103 packets, 10638278904 bytes
          5 minute rate 0 bps
        Match: ip dscp ef (46)
          29035 packets, 6198530 bytes
          5 minute rate 0 bps
        Queueing
          Strict Priority
          Output Queue: Conversation 264
          Bandwidth 500 (kbps) Burst 12500 (Bytes)
         (pkts matched/bytes matched) 0/0
          (total drops/bytes drops) 0/0
        217382198 packets, 53491210234 bytes
        Match: any
           5 minute rate 0 bps
           5 minute rate 0 bps
         Queueing
           Strict Priority
          (pkts matched/bytes matched) 0/0   <<<<<<<<<<<<-show matches only during congestions which when packets get queued
We two packet counters in a class
  • •1)      Packets
   Which means the number of packets which match the criteria of the class. This counter increments whether or not the interface is congested.
  • 2)      (pkts matched/bytes matched) 0/0
      Which mean the number of packets which match the criteria of the class when the interface was congested. In other words, the interface transmit ring was full, and the driver and the L3 processor system worked together to queue the excess packets in the L3 queues, where the service policy applies. Packets that are process-switched always go through the L3 queuing system and thus increment the "packets matched" counter.
At the time this output was taken there is no congestion as the offered rate was 0 , and hence
(pkts matched/bytes matched) 0/0 is expected  .as this counter will only increment for processes switched packets or when there is congestion .
Here is a good link for reference
http://www.cisco.com/en/US/tech/tk543/tk760/technologies_tech_note09186a0080108e2d.shtml
desmond.s
Hello Sarala,
I have two sites:
Site A                   2 T1(3Mbps)                   Site B
2911----------------------------------------------------------2911
Multilink                                                     Multilink
Data Vlan                                                  Data Vlan
MGMT Vlan                                               MGMT Vlan
I want to ensure that the data vlan always has the highest priority sending traffic from A to B and B to A, how can I accomplish this?
Thank you!
Create a class-map to match Data Vlan Traffic
class-map
match vlan
Now create policy-map to mark the traffic
policy-map
class
  ...mark the traffic as needed
Now Apply the policy on the interfaces connected to 2911
interface
Verify:
You can look at the output "show policy-map interface "
Example:
class-map class-vlan
match vlan 100
policy-map policy-vlan
class class-vlan
interface gi1/1
service-policy output policy-vlan
Support Restrictions to match vlan:
The following restrictions apply to the match vlan command:
•The match vlan command is supported for IEEE 802.1q and Inter-Switch Link (ISL) VLAN encapsulations only.
•As of Cisco IOS Release 12.2(31)SB2, the match vlan command is supported on Cisco 10000 series routers only.
Here is the link:
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_m1.html#wp1038903
Another useful link:
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/qos_on_lac_ps6350_TSD_Products_Configuration_Guide_Chapter.html
Cisco-Spider
I have a question.
I have an agreement with my ISP for 100mb dedicated bandwidth. Can I test it using any QOS method ?
For testing purpose you can have policer for 100 MB which will controll the traffic so that it would not go beyond 100 MB
here is the sample configuration
policy-map LIMIT
class class-default
police  100000000
interface XXX
service-policy out LIMIT
show policy-map int XXX  should show the drops if packets go above 100 MBPS.
if you have a QoS policy  already then you will  be needing to configure 2 level  parent-child policy
