Ask The Export: EBGP Remote AS Ping Failure
Dear Cisco Community,
I am reaching out for assistance with troubleshooting an EBGP (External BGP) configuration issue. I have followed the necessary steps and configured EBGP on all routers, but I am unable to ping the network reachable through the remote Autonomous System (AS).
I have reviewed the available resources and troubleshooting guides, but I am still encountering this issue. To assist with further analysis, I have included the relevant configurations of all routers and a diagram of the network topology. ilug.png
2 Accepted Solutions
Harold Ritter
Hi @syedaijazahmed48 ,
All routers need routes to all of their eBGP neighbor addresses. The attached file doesn't show any static routes.
As an example you could configure the following static routes on R1:
ip route 2.2.2.2 255.255.255.255 12.1.1.2
ip route 3.3.3.3 255.255.255.255 13.1.1.2
It would also be better to configure neighbor statements only for adjacent ASes (i.e. for R1 only configure R2 and R3, for R2 only configure R1 and R4, etc)
In most real life cases, the eBGP session is established using the physical interface address, so ideally you would configure something like this:
R1:
router bgp 100
neighbor 12.1.1.2 remote-as 200
neighbor 13.1.1.2 remote-as 300
network 1.1.1.1 mask 255.255.255.255
R2:
router bgp 200
neighbor 12.1.1.1 remote-as 100
neighbor 24.1.1.1 remote-as 400
network 2.2.2.2 mask 255.255.255.255
R3:
router bgp 300
neighbor 13.1.1.1 remote-as 100
neighbor 34.1.1.1 remote-as 400
network 3.3.3.3 mask 255.255.255.255
R4:
router bgp 400
neighbor 24.1.1.2 remote-as 200
neighbor 34.1.1.2 remote-as 300
network 4.4.4.4 mask 255.255.255.255
6 Replies 6
Use redistrubte connect under bgp in all routers and try again
MHM
Harold Ritter
@Harold Ritter
Thank you so much for your response.
If you do not mind could you please provide me with an example it will be really helpful to me and my concept will be clear
R1:
router bgp 100
R2:
router bgp 200
R3:
router bgp 300
R4:
router bgp 400
Dear Mr. Ritter,
I wanted to express my sincere gratitude for the guidance and support you provided me with my recent technical challenge. Your expertise and patience were instrumental in resolving the issue, and I am deeply thankful for your assistance.
Additionally, I would like to acknowledge the Cisco Community for fostering an environment where collaboration and support thrive. It's a privilege to be part of such a knowledgeable and helpful community.
Thank you once again, Mr. Ritter, and the entire Cisco team, for your dedication and hard work.
Warm regards,
Syed Aijaz Ahmed.
You are very welcome @syedaijazahmed48 and thanks for the excellent feedback
