asking for your idea's regarding implementing network infra
hello all,
we have this network infra which we will be implementing:
in my encounter before.. if we tandem CISCo and HP..there will be likely an issues which will occur..
what will i do 1st in order to implement this setup?
starting from the core,distribution... then to its firewall... ??
can anyone share their overview on what to do regarding this network?
what configuration will i implement? (e.g. routing protocol, NAT, spanning tree..etc etc)
thanks so much
Gajendra R'
hi,
As far i understand you should start with your Firewall then your WAN routers and the LAN setup at all....
thanks Gajendra,
can you suggest what cisco dual wan router i will use as a core?
i serach in the net but i only see the RV series..
thanks
