access-list v cisco asa firewall
ohareka70
Level 3
Level 3
We have an external company who need access to our network through an ISDN line so they can get access to a few of our applications.  It is ok to patch their router into our Layer 3 switch which is on our OSPF network and then put an access-list on our L3 switch to only allow them access to the subnets where the servers are located.
Or is it better to do this with a Cisco 5520 ASA firewall between the two devices.  So really - is the access-list secure enough?
Kevin
mahmoodmkl
Level 7
Level 7
If implemented properly this can be done using ACL's.
mahmoodmkl
Level 7
Level 7
I have the access-list in place.  It can do a job for now until i get a chance to plug the isdn into the firewall.
thanks anyway,
Kevin
Access list can do blocking and permitting.. Then what is necessary of firewall over Access list..? can briefly explain the bugs in access list which can overcome by firewall..
hi Kevin,
to allow outside traffic Inside you will be require ACL to be configure. also i ll suggest you to configure ACL by permitting
that particular traffic to get the access of your servers.
