ASN Number Question
John Apricena
Hello Support,
We currently run BGP with two ISPs and will be moving to a new datacenter in the comings months. Can we use the same ASN number at the new site. The new site has the same ISPs and will be providing different Class C IPs. Can we setup that ASN number on new equipment at the new site even though we are already using our ASN number at our current datacenter? Thanks in advance as always for all your help guys!
John Apricena
bump for assistance..
Jon Marshall
John
Yes you should be able to use the same ASN if you are advertising different subnets.
Couple of points -
1) do you have a direct connection between the existing and new sites and as you proposing to use IBGP between the two or looking for each site to act as failover for the other
2) regardless of the above if you need the existing and new site to accept each others advertisements then you would need to use the "allowas-in" command for it work otherwise because both sites are using the same ASN then they would reject the route advertisements to each other because they see their own AS in the path.
Jon
