ASR 10001 Netflow stopped working after IOS upgrade
riazshams
Hi, Netflow on ASR1001 worked fine untill upgraded to asr1001-universalk9.03.13.03.S.154-3.S3
The configuration is given below
flow exporter FlowExporter1
 description Export to Produban
 destination XX.XX.XX.XX
 source Loopback1
 transport udp 9995
 export-protocol netflow-v5
flow monitor FlowMonitor1
 description Emulate traditional NetFlow
 cache timeout inactive 900
 cache timeout active 60
 record netflow ipv4 original-input
interface  Gix/y/z
 ip flow monitor FlowMonitor1 input
 ip flow monitor FlowMonitor1 output
Vinit Jain
Could you please share the IOS XE version (image) that you were using earlier.
Also, please share the output of below:
- show flow exporter statistics
Vinit
--Vinit
Hi Vinit,
It was asr1001-universalk9.03.07.02.S.152-4.S2
router#show flow exporter statistics
Flow Exporter FlowExporter1:
Packet send statistics (last cleared 20w5d ago):
Successfully sent: 105059 (5042832 bytes)
Client send statistics:
Client: Flow Monitor FlowMonitor1
Records added: 105059
- sent: 105059
Bytes added: 5042832
- sent: 5042832
the collector has stopped getting interface flows
james.jiang
I have same problem. after upgrade ios from 9.03.10.7h
 upgrade to 9.03.13.8, and netflow stop working.
