CISCO 3825 NAT help
I've recently aquired a cisco 3825, and I'm having a really hard time getting public wan to redirect to port 80 on a lan box running apache.. I've ran several "open port checks" online to see if the port ever came accessable via the internet. No luck.. I've tried everything I've came across, and I have absolutely no idea how to do this. I keep breaking my connectivity and it's causing my wife much grief. Any help would be greatly appreciated!
So my setup is:
1) my gateway device
2) 3825
3) switch
4) a nix box 192.168.0.4 with apache
5) lan
My config (as messy as it appears to be)
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
boot-start-marker
boot system flash:/c3825-advsecurityk9-mz.151-4.m6.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 emergencies
logging console critical
enable secret 5 $1$wmdL$GBG97JZorRpQlV0QCJHDc1
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
clock timezone NewYork -5 0
clock summer-time NewYork date Apr 6 2003 2:00 Oct 26 2003 2:00
dot11 syslog
no ip source-route
no ip dhcp use vrf connected
ip cef
no ip bootp server
ip domain name ofy.net
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip name-server 192.168.0.4
ip ips config location flash: retries 1
ip ips notify SDEE
ip ips name sdm_ips_rule
ip ips signature-category
  category all
   retired true
  category ios_ips advanced
   retired false
parameter-map type urlfpolicy trend cptrendparacatdeny0
 block-page message "The website you have accessed is blocked as per corporate policy"
parameter-map type urlf-glob cplocclassurlfglobkdblock0
parameter-map type urlf-glob cpaddbnwlocparadeny1
 pattern .netflix.com
parameter-map type trend-global global-param-map
crypto pki trustpoint test_trustpoint_config_created_for_sdm
 subject-name e=sdmtest@sdmtest.com
 revocation-check crl
license udi pid CISCO3825 sn FCZ1250719K
archive
 log config
  hidekeys
username admin privilege 15 secret 5 $1$LyP6$XsLii2Yz/M8uTnLKrlSZJ/
redundancy
crypto key pubkey-chain rsa
 named-key realm-cisco.pub
  key-string
  quit
ip tcp selective-ack
ip tcp mss 10000
ip tcp synwait-time 10
no ip ftp passive
class-map type inspect match-any SDM_BOOTPC
 match access-group name SDM_BOOTPC
class-map type inspect match-all sdm-nat-http-1
 match access-group 101
 match protocol http
class-map type inspect match-any SDM_DHCP_CLIENT_PT
 match class-map SDM_BOOTPC
class-map type inspect match-all SDM_GRE
 match access-group name SDM_GRE
class-map type inspect match-any CCP_PPTP
 match class-map SDM_GRE
class-map type inspect match-any ccp-skinny-inspect
 match protocol skinny
class-map type inspect match-any sdm-cls-bootps
 match protocol bootps
class-map type inspect match-any ccp-cls-insp-traffic
 match protocol pptp
 match protocol dns
 match protocol ftp
 match protocol https
 match protocol icmp
 match protocol imap
 match protocol pop3
 match protocol netshow
 match protocol shell
 match protocol realmedia
 match protocol rtsp
 match protocol smtp
 match protocol sql-net
 match protocol streamworks
 match protocol tftp
 match protocol vdolive
 match protocol tcp
 match protocol udp
class-map type inspect match-all ccp-insp-traffic
 match class-map ccp-cls-insp-traffic
class-map type urlfilter match-any cpaddbnwlocclassdeny1
 match  server-domain urlf-glob cpaddbnwlocparadeny1
class-map type inspect match-any ccp-h323nxg-inspect
 match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
 match protocol icmp
 match protocol tcp
 match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
 match protocol h225ras
class-map type inspect match-all ccp-cls-ccp-inspect-1
 match access-group name EVERYTHING
class-map type urlfilter trend match-any cptrendclasscatdeny0
class-map type inspect match-any ccp-h323annexe-inspect
 match protocol h323-annexe
class-map type urlfilter match-any cplocclasskdblock0
 match  url-keyword urlf-glob cplocclassurlfglobkdblock0
class-map type urlfilter trend match-any cptrendclassrepdeny0
class-map type inspect match-any ccp-h323-inspect
 match protocol h323
class-map type inspect match-all ccp-invalid-src
 match access-group 100
class-map type inspect match-all ccp-icmp-access
 match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
 match protocol sip
class-map type inspect match-all ccp-protocol-http
 match protocol http
policy-map type inspect ccp-permit-icmpreply
 class type inspect sdm-cls-bootps
  pass
 class type inspect ccp-icmp-access
  inspect
 class class-default
  pass
policy-map type inspect ccp-inspect
 class type inspect ccp-invalid-src
  drop log
 class type inspect ccp-protocol-http
  inspect
 class type inspect ccp-insp-traffic
  inspect
 class type inspect ccp-sip-inspect
  inspect
 class type inspect ccp-h323-inspect
  inspect
 class type inspect ccp-h323annexe-inspect
  inspect
 class type inspect ccp-h225ras-inspect
  inspect
 class type inspect ccp-h323nxg-inspect
  inspect
 class type inspect ccp-skinny-inspect
  inspect
 class type inspect ccp-cls-ccp-inspect-1
  pass
 class class-default
  drop
 class type inspect SDM_DHCP_CLIENT_PT
  pass
 class class-default
  drop
policy-map type inspect urlfilter badsite
 class type urlfilter cpaddbnwlocclassdeny1
  reset
  log
policy-map type inspect ccp-pol-outToIn
 class type inspect CCP_PPTP
  pass
 class type inspect sdm-nat-http-1
  pass
 class class-default
  drop log
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
 service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-out-zone-To-in-zone source out-zone destination in-zone
 service-policy type inspect ccp-pol-outToIn
zone-pair security ccp-zp-in-out source in-zone destination out-zone
 service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
buffers tune automatic
interface Null0
 no ip unreachables
interface GigabitEthernet0/0
 description **WAN**$ETH-WAN$
 ip address dhcp client-id GigabitEthernet0/0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 no ip nat outside
 ip nat enable
 ip ips sdm_ips_rule in
 ip virtual-reassembly in
 duplex auto
 speed auto
 media-type rj45
 no mop enabled
interface GigabitEthernet0/1
 description **LAN**$ETH-LAN$
 ip address 192.168.0.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 no ip nat inside
 ip nat enable
 zone-member security in-zone
 duplex auto
 speed auto
 media-type rj45
 no mop enabled
interface Content-Engine1/0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
router rip
 passive-interface GigabitEthernet0/0
 passive-interface GigabitEthernet0/1
 network 192.168.0.0
 no auto-summary
ip forward-protocol nd
ip http server
ip http access-class 3
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat source list INSIDE_NAT_ADDR interface GigabitEthernet0/0 overload
ip nat source static tcp 192.168.0.4 80 interface GigabitEthernet0/0 80
no ip nat inside source static tcp 192.168.0.4 80 interface GigabitEthernet0/0 80
no ip nat inside source list 4 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip access-list standard INSIDE_NAT_ADDR
 permit 192.168.0.1 0.255.255.255
ip access-list extended EVERYTHING
 remark CCP_ACL Category=128
 permit ip any any
ip access-list extended SDM_BOOTPC
 remark CCP_ACL Category=0
 permit udp any any eq bootpc
ip access-list extended SDM_GRE
 permit gre any any
logging trap debugging
access-list 1 remark INSIDE_IF=GigabitEthernet0/1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit any
access-list 2 remark HTTP Access-class list
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 2 deny   any
access-list 3 remark HTTP Access-class list
access-list 3 remark CCP_ACL Category=1
access-list 3 permit 192.168.0.0 0.0.0.255
access-list 3 deny   any
access-list 4 remark INSIDE_IF=GigabitEthernet0/1
access-list 4 remark CCP_ACL Category=2
access-list 4 permit 192.168.0.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=0
access-list 101 permit ip any host 192.168.0.4
no cdp run
control-plane
banner login ^CCCUnauthorized access prohibited.^C
line con 0
 transport output telnet
line aux 0
line 66
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
 login authentication local_authen
 transport input telnet ssh
scheduler allocate 20000 1000
end
below is the sanitized configuration that should get you Internet connectivity. The Zone Based Firewall might still cause you trouble...do you really need that ?
Either way, I have marked the important parts in bold:
version 15.1
no service pad
boot-start-marker
boot-end-marker
aaa new-model
dot11 syslog
no ip source-route
ip cef
no ip bootp server
ip ips notify SDEE
category all
retired true
retired false
archive
log config
hidekeys
redundancy
key-string
quit
ip tcp mss 10000
no ip ftp passive
match protocol http
match protocol pptp
match protocol dns
match protocol ftp
match protocol icmp
match protocol imap
match protocol pop3
match protocol rtsp
match protocol smtp
match protocol tftp
match protocol tcp
match protocol udp
match protocol icmp
match protocol tcp
match protocol udp
match protocol h323
match protocol sip
match protocol http
pass
inspect
class class-default
pass
drop log
inspect
inspect
inspect
inspect
inspect
inspect
inspect
inspect
pass
class class-default
drop
pass
class class-default
drop
reset
log
pass
pass
class class-default
drop log
interterface Null0
no ip unreachables
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
duplex auto
speed auto
media-type rj45
no mop enabled
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
duplex auto
speed auto
media-type rj45
no mop enabled
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
router rip
network 192.168.0.0
no auto-summary
ip http server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
permit ip any any
permit gre any any
no cdp run
control-plane
line con 0
line aux 0
line 66
no exec
transport input all
line vty 0 4
end
6 Replies 6
before delving into your configuration: what is the gateway device ? Is that another modem/router between the 3825 and the Internet ?
It's a xFinity eMTA bridged directly to the 3825
version 15.1
no service pad
boot-start-marker
boot-end-marker
aaa new-model
dot11 syslog
no ip source-route
ip cef
no ip bootp server
ip ips notify SDEE
category all
retired true
retired false
archive
log config
hidekeys
redundancy
key-string
quit
ip tcp mss 10000
no ip ftp passive
match protocol http
match protocol pptp
match protocol dns
match protocol ftp
match protocol icmp
match protocol imap
match protocol pop3
match protocol rtsp
match protocol smtp
match protocol tftp
match protocol tcp
match protocol udp
match protocol icmp
match protocol tcp
match protocol udp
match protocol h323
match protocol sip
match protocol http
pass
inspect
class class-default
pass
drop log
inspect
inspect
inspect
inspect
inspect
inspect
inspect
inspect
pass
class class-default
drop
pass
class class-default
drop
reset
log
pass
pass
class class-default
drop log
interterface Null0
no ip unreachables
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
duplex auto
speed auto
media-type rj45
no mop enabled
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
duplex auto
speed auto
media-type rj45
no mop enabled
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
router rip
network 192.168.0.0
no auto-summary
ip http server
permit ip any any
permit gre any any
no cdp run
control-plane
line con 0
line aux 0
line 66
no exec
transport input all
line vty 0 4
end
I'd prefer to see this configuration as it would be in someone that inherently knows what should, and shouldn't be there. I'm not overly concerned about a firewall. I really do appreciate it :-)
Well, I took your advice and removed the firewall..
What's ironic here is -- my connectivity has improved, I have some-what less latency, and port 80 is open. Man, you guys rock
My new configuration:
version 15.1
no service pad
hostname ORION
boot-start-marker
boot-end-marker
aaa new-model
dot11 syslog
no ip source-route
ip cef
no ip bootp server
archive
 log config
  hidekeys
redundancy
  key-string
  quit
ip tcp mss 10000
no ip ftp passive
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 duplex auto
 speed auto
 media-type rj45
 no mop enabled
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
 duplex auto
 speed auto
 media-type rj45
 no mop enabled
router rip
 network 192.168.0.0
 no auto-summary
ip http server
no cdp run
control-plane
banner login ^CCCCUnauthorized access prohibited.^C
line con 0
line aux 0
line 66
 no exec
 transport input all
line vty 0 4
end
actually there are a few more things in your configuration that might not be necessary. Do you need RIP to connect to something on your internal network ?
What is the Internet speed you get from your provider ? Since you say you experience latency (and assuming you don't have a 1000Mbit connection), a simple traffic shaping policy might help. Can you post the output of 'show interfaces GigabitEthernet0/0' , to see if there is congestion on the interface ?
