ASR 1001 IOS Upgrade
lsouthwood
I just did an IOS upgrade on a new ASR 1001 router. After I do the upgrade, the permanent license I had for adventerprise changed from permanent to EvalRightToUse. Is there something that I must do to get it changed back t opermanent again? It appears that the license will expire in 60 days. If it does expire, will the router revert to IP Base level?
rtr1#sho license all
License Store: Primary License Storage
License Store: Built-In License Storage
StoreIndex: 0 Feature: adventerprise          Version: 1.0
            License Type: EvalRightToUse
            License State: Active, In Use
                  Evaluation total period: 8 weeks 4 days
                  Evaluation period left: 8 weeks 3 days
                  Period used: 38 minutes 10 seconds
                  Transition date: Aug 30 2013 09:22:28
           License Count: Non-Counted
           License Priority: Low
Lloyd
Leo Laohoo
Check the logs.  Maybe you didn't accept the EULA.
I'll look again when I get a chance. I thought I had excepted the EULA, but maybe not. Is that all that needs to be done is to except the EULA?
I checked the ASR 1001 again and I did accept the EULA:
Show License EULA
Feature name     EULA Accepted
adventerprise      yes
However, when I do a show license right-to-use, I get a message that says, "%No RightToUse Licenses are Active!!". The show license all still have a license type of EvalRightToUse and an evaluation period left time. When the evaluation ends, does it juse convert to RTU? Or wil this router get put back to IPBase?
Lloyd
I have the same problem, and I don´t know what can i do.
