ASR 1001 - QoS - How to allow queues to burst
joerggrau
I am running a number of ASR1001s running 15.1(1)S.  I have QoS setup but see drops in some of the queues from time to time.  I know we have the bandwidth to accommodate the traffic.  There has to be a way to allow the queues to go beyond their bandwidth limitations if there is bandwidth available.
Here is the current config:
class-map match-any Node-AF31
match ip dscp af31
match access-group name U-AF31
class-map match-any Node-AF21
match ip dscp af21
match access-group name U-AF21
class-map match-any Node-Voice
match ip dscp ef
policy-map DM_QoS
class Node-Voice
  priority 35000
  set dscp ef
class Node-AF31
  bandwidth 20000
  set dscp af31
class Node-AF21
  bandwidth 15000
  set dscp af21
class class-default
  set dscp default
policy-map QOS-PARENT
class class-default
  shape average 70000000
  service-policy DM_QoS
int g0/0/0.1
service-policy output QOS-PARENT
How can I allow the queues to go beyond the bandwidth limits put on them?
Joerg
Hello
The Bandwidth XXX - actual value to be assigned to that class regardless of any increase in link BW -
Bandwidth percent - % of whatever the link bw is - this will incrrease as the link BW increases.
Bandwidth remaining percent = the remaining amount of BW available - meaning it will get its % vaule of any remaining available BW
Also by default class class-default automatically gets 25% of defined BW for routing process etc which can be a bit to high is you have a large BW value set on the outgoing interface - this can be changed  by the max-reserved-bandwidth command which would allow this extra BW to be shared between the other classes.
int g0/0/0.1
max-reserved-bandwidth 95
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Actually, in pre-HQF CBWFQ, by default you're unable to define more than 75% of bandwidth to named classes without using the max-reserved-bandwidth command.  So in the pre-HQF variant of CBWFQ, class-default class should by default have at least, but may have more (if other classes didn't allocation the full 75%) than, a 25% bandwidth guarantee.  However, also keep in mind, regardless of bandwidth allocations unused bandwidth is available to other classes.  I.e. bandwidth settings (excluding LLQ) set a guarantee minimum, not a maximum.
You can juggle bandwidth allocations per class to reduce drop rates of some classes when there's bandwidth competition between classes.  However, doing this often leads to increased drop rates for other classes as you're basically taking bandwidth from one class (or classes) and providing it to another class (or classes).
Joseph W. Doherty
Disclaimer
Posting
If there was short term available bandwidth, your traffic wouldn't queue.  If you do have long term available bandwidth, you just need to increase your queue limits so the short term bursts don't overflow their queues while they drain over the long term.  (NB:  Of course, when you increase queue depths you also often increase latency and you might encourage rate adaptive flows to try to go beyond currently available bandwidth.)
