ASR 1001-x router not able to create the vlan
csco10979295
  I am configuring ASR1001-x router . but not able to configure the vlan and the port-channel.
   we have ADV-ip serivces license . any suggestions
6 Replies 6
Seb Rupik
Hi there,
How are you going about configuring the VLANs and port-channels. As the ASR is a router this will be acheived by creating sub-interfaces on the port-channel:
int po1.1100
  encapsulation dot1q 1100
  ip address <ip_address> <subnet_mask>
cheers,
Seb.
Hi Rupik,
    Thank you for your reply. I am planning to create the portchannel - and two physical interface in it.
     L3 Portchannle
      Int port-chan 101
          IP < >
        inter Gi0/0/0 -1
             channel-grpup 101
              no shut
But i can see the port-channel down
What is the ouput from:
sh ip int br | inc 0/0/
sh etherchanel summary
show etherchannel summary
Flags: D - down P/bndl - bundled in port-channel
I - stand-alone s/susp - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 0
Number of aggregators: 0
Group Port-channel Protocol Ports
RU - L3 port-channel UP State
SU - L2 port-channel UP state
P/bndl - Bundled
S/susp - Suspended
Router #sh ip int brief | in 0/0
Te0/0/0 unassigned YES NVRAM administratively down down
Te0/0/1 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/0 x.x.x.x YES manual down down
GigabitEthernet0/0/1 unassigned YES NVRAM down down
GigabitEthernet0/0/2 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/3 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/4 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/5 unassigned YES NVRAM administratively down down
Also tried to configure the reverse. Let me try to connect the ports
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
1 Po1(RD) LACP Gi0/0/0(D) Gi0/0/1(D)
P/bndl - Bundled
S/susp - Suspended
Delete the port channel and reverse your order of these commands. Physical interfaces first then apply configs on the port channel.
Allow the router to create the port channel rather than creating it manually.
Hope it helps,
Paul
