ASR 1001-X UPGRADE via CLI OR GUI
is there someone that can help me to upgrade my ASR 1001-X via GUI? For being more specific I have a problem when a path is requested, if I have my .bin file in my PC's downloads folder, which path do I have to insert?
I tried to follow this guide via CLI https://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/asrswcfg/issu.html
but the TFTP transfer isn't functioning properly.
Thank you in advance.
Matteo
11 Replies 11
 It depends. Which Operating system are you using? If you are using Windows, download should be something like:
C:\Users\You-user\Downloads
at the moment I uploaded the target release on a Nexus 9K directly attached to the router, the current release is the 16.6.4.
This is my current config for the ASR side:
Router_ASR#sh run
Building configuration...
Current configuration : 2676 bytes
! Last configuration change at 16:55:47 UTC Mon Jan 17 2022 by admin
version 16.6
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname xxxxxxxxxx
boot-start-marker
boot system bootflash:Downloads
boot system bootflash:asr1001x-universalk9.16.06.04.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
ip domain name xxxx
subscriber templating
license udi pid ASR1001-X sn JAE253700HD
license boot level adventerprise
diagnostic bootup level minimal
username admin privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxx
username superuser privilege 2 password 0 superpassword
redundancy
 mode sso
lldp run
cdp run
interface Port-channel15
 no ip address
interface Port-channel15.970
 encapsulation dot1Q 970
 ip address x.x.x.x 255.255.255.224
 standby 10 ip x.x.x.x
 standby 10 preempt
 standby 10 track 1 decrement 10
 shutdown
interface TenGigabitEthernet0/0/0
 ip address 10.1.1.1 255.255.255.252
interface TenGigabitEthernet0/0/1
 no ip address
 channel-group 15 mode active
interface GigabitEthernet0/0/0
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/1
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/3
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/4
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/5
 no ip address
 shutdown
 negotiation auto
 vrf forwarding Mgmt-intf
 ip address 10.19.0.14 255.255.255.224
 negotiation auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0
ip tftp blocksize 8192
ip route vrf Mgmt-intf 0.0.0.0 0.0.0.0 10.19.0.1
ip ssh source-interface GigabitEthernet0
ip ssh version 2
ip scp server enable
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 transport input ssh
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
This is my current config for the Nexus side:
switch_N9K# sh running-config
!Command: show running-config
!Running configuration last done at: Mon Jan 17 16:42:49 2022
!Time: Mon Jan 17 18:09:23 2022
version 9.3(8) Bios:version 01.05
feature scp-server
feature sftp-server
feature tacacs+
cfs eth distribute
feature ospf
feature interface-vlan
feature lacp
feature vpc
feature lldp
feature bfd
no ip domain-lookup
crypto key generate rsa label AC-CAGS-SW01-EXT modulus 2048
ip tftp source-interface mgmt0 vrf management
vrf context management
  ip route 0.0.0.0/0 10.19.0.1
interface Ethernet1/1
  ip address 10.1.1.2/30
  no shutdown
interface mgmt0
  vrf member management
  ip address 10.19.0.10/27
boot nxos bootflash:/nxos.9.3.8.bin
logging server xxxxxx
Richard Burts
Do you have the tftp server software installed and running on your PC? If so can you set its default directory to be your downloads folder?
Rick
Yes but instead of using my PC, I want to use the N9K that is directly attached to the ASR for uploading the target release, for doing this I suppose to use SCP but for the moment it isn't functioning. In the previous answer, I pasted the current configurations both for N9K both ASR
Sorry Leo but at the moment my problem is to copy the bin file into the ASR, I have a Nexus 9K (with the ASR target release onboard) directly connected with the ASR 1001-X, trying to do the copy via SCP it isn't functioning, it displays an undefined error when trying to retrieve the release from the Nexus.
Check the configurations posted in the previous answer if you want to help me.
Thanks in advance
Matteo
The file could be uploaded to the router using the on-board USB port.
Do you have the detailed procedure to copy the image from USB to the ASR and to proceed with the upgrade?
Thanks in advance
copy usb0:filename.ext bootflash:
Please refer to my previous response (LINK).
It seems that the router is not able to read what is contained into the usb:
copy usb0: bootflash:asr1001x-universalk9.17.03.04a.SPA.bin
Source filename []? asr1001x-universalk9.17.03.04a.SPA.bin
Destination filename [asr1001x-universalk9.17.03.04a.SPA.bin]?
%Error opening usb0:asr1001x-universalk9.17.03.04a.SPA.bin (No such file or directory)
Do you have any suggestions?
Post the complete output to the command "dir usb0:".
