- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-18-2022 06:38 PM
Hello My Dear Friends,
I have C800 router, created a vlan and assigned a network with 14 available IPs, so site side they will connect there devices to the router and they will assign IP from those 14 IPs, now the problem is there is device called E-Guard which can take IP only via DHCP, we don't have option to configure IP manually at E-Guard, we have free IPs but how to make communication without assigning ip, moreover we have one L3 interface connected to WAN and remain all are L2 interfaces.
Is there option to create a dhcp pool with defined IPs and to make communication, if yes could you please provide the sample configuration to understand the things.
Appreciated your suggestions and valuable inputs.
Solved! Go to Solution.
- Labels:
Community Ideas
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2022 12:55 AM
Hello
mahendarec@123 wrote:
Unfortunatly it's not possible to assign the IP on end e-guard device device, i don't have other option.
This is why i suggested you can append a static dhcp pool on the router and let that E-Guard device receive ip addressing automatically
Kind Regards
Paul
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-18-2022
11:59 PM
- last edited on
01-19-2022
05:44 AM
by
Translator
Hello
The router should be able to support a dhcp service, but I assume the above means you statically assign addressing to these clients at present, if so and you wish for just this single host to receive dhcp then you can apply a static dhcp pool for it.
Lastly can you confirm if you a using Network Address Translation?
Example of a static dhcp pool
IP/Mac address of E-Guard using a /28 addressing-
192.168.1.12
0111.1111.1111
ip dhcp pool static
client-identifier 0101.1111.1111.11 ( 01 extension added to mac add of client)
host 192.168.1.12 255.255.255.240
default-router 192.168.1.1
dns 192.168.1.1
lease 0 12
Kind Regards
Paul
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2022 12:42 AM
what E-Guard device is that, what model/type ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2022 12:52 AM
@paul driver @Georg Pauwen : Thanks for your both the response.
@paul driver : Unfortunatly it's not possible to assign the IP on end e-guard device device, i don't have other option.
@Georg Pauwen : it's somedevice i heard it can take ip only via dhcp no settings to assign ip manually.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2022 12:55 AM
Hello
Kind Regards
Paul
