ASR 1001-X with 3 ISP's terminated
Rajan R
I have a ASR 1001-X. Have 3 ISP's which I want to terminate onto it.
Have 3 VLANs on my 6509E switch. Vlan 10,20 and 30.
Vlan 10 uses ISP1, Vlan20 uses ISP2 and vlan 30 uses ISP3.
How do I do the above on ASR.
Also, if ISP1 fails how does vlan10 automatically use ISP2 or ISP3 ?
Thanks in advance.
balaji.bandi
how is your ISP connections terminating ? in to ASR or in to Ethernet to switch ?
BB
Into ASR.
Thanks for the response.
Sure Look at the example for Dual ISP Fail over with NAT. Same will apply for 3 ISP
http://binaryglobal.com/blog/?p=129
BB
