Dears,
Does Somebody know if there are limitations of POOL NAT on Cisco Routers ASR 1002 series routers?
I tryied to configure a POOL NAT and not worked properly, but when I configure with overload in interfaces, it worked ok.
It follows below, the both configuration, first, with POOL NAT and second, without POOL NAT, only Overload in interfaces.
#### CONFIG WITH POOL NAT ####
interface GigabitEthernet0/0/1.1032
description FW-ASA - FrontEnd - DMZ
encapsulation dot1Q 1032
ip vrf forwarding A
ip address 192.168.218.99 255.255.255.224
ip nat inside
ip virtual-reassembly
standby 4 ip 192.168.218.97
standby 4 preempt
standby 4 track 100 decrement 1
interface GigabitEthernet0/1/5.150
description Conexao_BB_Extremus
encapsulation dot1Q 150
ip vrf forwarding A
ip address 10.250.10.102 255.255.255.240
ip nat outside
ip nat pool MUDA-IP-SISBB 10.250.10.103 10.250.10.103 netmask 255.255.255.0
ip nat inside source list NAT-SISBB pool MUDA-IP-SISBB vrf A overload
ip access-list extended NAT-SISBB
permit ip 10.200.0.0 0.7.255.255 host 170.66.50.244
permit ip 10.0.28.0 0.0.3.255 host 170.66.50.244
permit ip 10.0.32.0 0.0.3.255 host 170.66.50.244
#### CONFIG WITHOUT POOL NAT ####
ip vrf forwarding A
ip nat inside
standby 4 preempt
ip vrf forwarding A
ip nat outside
ip nat inside source list NAT-SISBB interface GigabitEthernet0/3/5.150 vrf parceiros overload
