ASR 1002 Problem
Hi All.
I just got a demo unit of Cisco ASR 1002-F but the problem is the ESP and the RP not working. Here are logs:
*Feb  2 18:22:09.292: %CPPHA-3-FAULT: F0: cpp_ha:  CPP:0 desc:CPP Client process
failed: FMAN-FP det:HA class:CLIENT_SW sev:FATAL id:1 cppstate:RUNNING res:UNKN
OWN flags:0x0 cdmflags:0x0
*Feb  2 18:22:09.294: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP MDM while
client(s) still connected
*Feb  2 18:22:09.402: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process fman_fp_im
age has been helddown (rc 134)
*Feb  2 18:22:09.429: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process cpp_ha_top
_level_server has been helddown (rc 69)
*Feb  2 18:22:19.006: %ASR1000_RP_ALARM-6-INFO: CLEAR MAJOR module F0 Boot state
*Feb  2 18:22:19.006: %ASR1000_RP_ALARM-6-INFO: ASSERT MAJOR module F0 Unknown s
tate
*Feb  2 18:22:19.006: %ASR1000_RP_ALARM-6-INFO: ASSERT CRITICAL module R0 No Wor
king ESP
*Feb  2 18:22:26.526: %ASR1000_RP_ALARM-6-INFO: CLEAR MAJOR module F0 Unknown st
ate
*Feb  2 18:22:26.526: %ASR1000_RP_ALARM-6-INFO: ASSERT MAJOR module F0 Disabled
*Feb  2 18:22:28.827: %ASR1000_RP_ALARM-6-INFO: CLEAR MAJOR module F0 Disabled
*Feb  2 18:22:28.828: %ASR1000_RP_ALARM-6-INFO: ASSERT MAJOR module F0 Boot stat
e
*Feb  2 18:29:34.357: %CPPHA-7-START: F0: cpp_ha:  CPP 0 preparing image /tmp/sw
/fp/0/0/fp/mount/usr/cpp/bin/cpp-mcplo-ucode
*Feb  2 18:29:34.773: %CPPHA-7-START: F0: cpp_ha:  CPP 0 startup init image /tmp
/sw/fp/0/0/fp/mount/usr/cpp/bin/cpp-mcplo-ucode
*Feb  2 18:29:39.573: %CPPHA-7-START: F0: cpp_ha:  CPP 0 running init image /tmp
*Feb  2 18:29:39.822: %CPPHA-7-READY: F0: cpp_ha:  CPP 0 loading and initializat
ion complete
*Feb  2 18:29:41.203: %IOSXE-6-PLATFORM: F0: cpp_cp: Process CPP_PFILTER_EA_EVEN
T__API_CALL__REGISTER
*Feb  2 18:29:44.000: %ASR1000_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
*Feb  2 18:29:44.001: %ASR1000_RP_ALARM-6-INFO: ASSERT MAJOR module F0 Boot stat
e
*Feb  2 18:30:21.251: %CPPHA-3-FAULT: F0: cpp_ha:  CPP:0 desc:CPP Client process
*Feb  2 18:30:21.253: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP MDM while
*Feb  2 18:30:21.357: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process cpp_ha_top
*Feb  2 18:30:21.359: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process fman_fp_im
*Feb  2 18:30:21.493: %PMAN-0-PROCFAILCRIT: F0: pvp.sh:  A critical process fman
_fp_image has failed (rc 134)
*Feb  2 18:30:31.032: %ASR1000_RP_ALARM-6-INFO: CLEAR MAJOR module F0 Boot state
*Feb  2 18:30:31.032: %ASR1000_RP_ALARM-6-INFO: ASSERT MAJOR module F0 Unknown s
tate
*Feb  2 18:30:31.032: %ASR1000_RP_ALARM-6-INFO: ASSERT CRITICAL module R0 No Wor
king ESP
*Feb  2 18:30:38.544: %ASR1000_RP_ALARM-6-INFO: CLEAR MAJOR module F0 Unknown st
ate
*Feb  2 18:30:38.544: %ASR1000_RP_ALARM-6-INFO: ASSERT MAJOR module F0 Disabled
*Feb  2 18:30:40.847: %ASR1000_RP_ALARM-6-INFO: CLEAR MAJOR module F0 Disabled
*Feb  2 18:30:40.847: %ASR1000_RP_ALARM-6-INFO: ASSERT MAJOR module F0 Boot stat
e
I need it to be solve immediately as this demo unit is for POC.
Thank You.
5 Replies 5
Leo Laohoo
Can you please post the "sh version"?
Thank you for your reply. Here are the show version
Router(config)#do sho vers
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version
12.2(33)XND2t, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 09-Jun-10 13:29 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2009 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 3 minutes
Uptime for this control processor is 5 minutes
System returned to ROM by reload
System image file is "bootflash:asr1000rp1-adventerprisek9.02.04.02t.122-33.XND2
t.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1002-F (2RU) processor with 1755313K/6147K bytes of memory.
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7798783K bytes of eUSB flash at bootflash:.
Wow!  IOS is 2.4.2!  That's OLD!
Can you try to upgrade the IOS?
Can you advise me the stabile IOS for this unit? Because this is a demo unit from Cisco, I feel uneasy to upgrade the software.
Whatever you want.  Just read the Release Notes.
After all, it is a DEMO UNIT.  So it's not going to hurt anyone.
