ASR 1002 VPDN PPTP problem
Dima Dvorcovoy
I have ASR and want to configure is as VPN server
=Device:=
cisco ASR1002-X (2RU-X) processor (revision 2KP) with 3746359K/6147K bytes of memory.
Processor board ID FOX2449P4F0
=IOS:=
Cisco IOS XE Software, Version 17.05.01a
Cisco IOS Software [Bengaluru], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.5.1a, RELEASE SOFTWARE (fc3)
=Configuration=
aaa authentication ppp RADCIT group radius
vpdn-group pptp
description pptp loopback
accept-dialin
protocol any
virtual-template 2
source-ip 10.149.88.1
no l2tp tunnel authentication
license udi pid ASR1002-X sn JAE25090EE4
ip local pool vpn-pool 10.149.88.2 10.149.88.254
interface Virtual-Template2
description test pptp
ip unnumbered Loopback1
peer default ip address pool vpn-pool
ppp authentication chap ms-chap-v2 ms-chap RADCIT
interface Loopback1
description VPDN target
ip address 10.149.88.1 255.255.255.0
radius server CIT
address ipv4 1.2.3.4 auth-port 1812 acct-port 1813
key 7 **************
= problem=
CAN establish connection successfully.
who ...
Interface User Mode Idle Peer Address
Vi2.1 dvorc PPPoVPDN - 10.149.88.6
show vpdn session
PPTP Session Information Total tunnels 1 sessions 1
LocID RemID TunID Intf Username State Last Chg Uniq ID
13388 31757 10395 Vi2.1 dvorc estabd 01:54:06 10
Gateway of last resort is 10.0.0.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.0.0.1
10.0.0.0/8 is variably subnetted, 5 subnets, 3 masks
C 10.0.0.0/9 is directly connected, GigabitEthernet0/0/0
L 10.8.8.8/32 is directly connected, GigabitEthernet0/0/0
C 10.149.88.0/24 is directly connected, Loopback1
L 10.149.88.1/32 is directly connected, Loopback1
C 10.149.88.6/32 is directly connected, Virtual-Access2.1
But I can't pass any data to this interface. I I turned on icmp debug and do traceroute 10.132.0.1 from client.
I see:
Dec 10 11:05:54: ICMP: time exceeded (time to live) sent to 10.149.88.6 (dest was 10.132.0.1), topology BASE, dscp 0 topoid 0
Dec 10 11:05:57: ICMP: time exceeded (time to live) sent to 10.149.88.6 (dest was 10.132.0.1), topology BASE, dscp 0 topoid 0
And no incoming packets on client PC ppp interface ever.
14 Replies 14
which VPN client (native Windows 10/11, AnyConnect) clients are you using ? Try and change the ip unnumbered in your Virtual Template from Loopback 1 to the actual WAN interface...
Windows 7/64 native, security: PPTP, no crypt, chap, net: ip4 only, no default gw, auto metrics
The problem is I have to use IP address not connected to any real providers, because they are changing.
Dima Dvorcovoy
Tried:
interface GigabitEthernet0/0/0
description CONNECTION
ip address 10.149.88.1 255.255.255.0 secondary
ip address 10.8.8.8 255.128.0.0
negotiation auto
crypto map VPNS
end
ip unnumbered GigabitEthernet0/0/0
end
Exactly the same result.
Dima Dvorcovoy
Dec 10 12:47:28: IP: tableid=0, s=10.149.88.16 (Virtual-Access2.1), d=10.132.0.1 (GigabitEthernet0/0/0) nexthop=10.0.0.1, routed via FIB
Dec 10 12:47:28: IP: s=10.149.88.16 (Virtual-Access2.1), d=10.132.0.1 (GigabitEthernet0/0/0), len 60, output feature, feature skipped, IPSec output classification(36), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Dec 10 12:47:28: IP: s=10.149.88.16 (Virtual-Access2.1), d=10.132.0.1 (GigabitEthernet0/0/0), len 60, output feature, feature skipped, IPSec: to crypto engine(85), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Dec 10 12:47:28: IP: s=10.149.88.16 (Virtual-Access2.1), d=10.132.0.1 (GigabitEthernet0/0/0), len 60, output feature, feature skipped, Post-encryption output features(86), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Dec 10 12:47:28: IP: s=10.149.88.16 (Virtual-Access2.1), d=10.132.0.1 (GigabitEthernet0/0/0), g=10.0.0.1, len 60, forward
Dec 10 12:47:28: IP: s=10.149.88.16 (Virtual-Access2.1), d=10.132.0.1 (GigabitEthernet0/0/0), len 60, pre-encap feature, feature skipped, IPSec Output Encap(1), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Dec 10 12:47:28: IP: s=10.149.88.16 (Virtual-Access2.1), d=10.132.0.1 (GigabitEthernet0/0/0), len 60, pre-encap feature, feature skipped, Crypto Engine(3), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Border-New#
not good. Can you post your full running config (so I can see the crypto stuff) ?
Remains from an l2tp test. But I need pptp.
Border-New(config)#int g0/0/0
Border-New(config-if)#no crypto map
same result. Have I to remove it completely?
not sure what you mean...
Either way, post the full output of:
sh run
Dima Dvorcovoy
! Last configuration change at 12:09:34 MST Fri Dec 10 2021
! NVRAM config last updated at 23:58:38 MST Thu Dec 9 2021 by dimad
version 17.5
service timestamps debug datetime
service timestamps log datetime
service password-encryption
service internal
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Border-New
boot-start-marker
boot system flash bootflash:asr1002x-universalk9.17.05.01a.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
aaa authentication login default local
aaa authentication login LDAPCITL group ldap
aaa authentication enable default none
aaa authentication ppp default local
aaa authentication ppp LDAPCIT group ldap
aaa authentication ppp FREE none
aaa authorization network FREE none
aaa authorization network LDAPCIT group ldap
aaa session-id common
aaa policy interface-config allow-subinterface
clock timezone MST 3 0
clock calendar-valid
ip address-pool local
ip name-server 10.0.0.20 10.0.0.21
ip domain name bsu
login on-success log
subscriber templating
vpdn enable
vpdn-group l2tp
description loopback vpdn
accept-dialin
protocol l2tp
virtual-template 1
source-ip 10.8.8.8
vpdn-group pptp
accept-dialin
protocol any
virtual-template 2
crypto pki trustpoint TP-self-signed-1326173215
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1326173215
revocation-check none
rsakeypair TP-self-signed-1326173215
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki trustpoint border
enrollment pkcs12
rsakeypair border
crypto pki trustpoint vpn
enrollment pkcs12
fqdn vpn.test.bsu
rsakeypair vpn
crypto pki certificate map CITUSER 1
issuer-name co "cn = bsu ad class 1 issuing subca 1"
crypto pki certificate map CITUSER 2
subject-name co "cn = inet, cn = bsu, cn = by"
crypto pki certificate chain TP-self-signed-1326173215
certificate self-signed 01
quit
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
quit
crypto pki certificate chain border
certificate 5C000588618141251DDDD21FC3000200058861
quit
certificate ca 3C00000009DDDD8721FEDA5261000100000009
quit
crypto pki certificate chain vpn
certificate 5C000597F61935428B2A11F4230002000597F6
... quit
... quit
http client secure-trustpoint bsu
memory free low-watermark processor 374622
diagnostic bootup level minimal
username dimad privilege 15 password 7 **************
username vpn nopassword type network-user
redundancy
mode none
cdp run
crypto isakmp policy 1
encryption aes 256
group 20
crypto isakmp policy 11
encryption aes 256
authentication pre-share
group 20
crypto isakmp key ****** address 0.0.0.0 no-xauth
crypto isakmp identity dn
crypto isakmp fragmentation
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 3600
crypto isakmp nat keepalive 20
crypto isakmp client configuration group CREM
pool vpn-pool
crypto isakmp profile VPN_CLIENT
ca trust-point vpn
match certificate CITUSER
crypto ipsec transform-set TL2TP7 esp-3des esp-sha-hmac
mode transport
crypto dynamic-map DMAP 10
set transform-set TL2TP7
crypto dynamic-map VPDNC 1
set isakmp-profile VPN_CLIENT
reverse-route
qos pre-classify
crypto map CMAP 10 ipsec-isakmp dynamic DMAP
crypto map VPNS client configuration address respond
crypto map VPNS 10 ipsec-isakmp dynamic VPDNC
interface Loopback1
negotiation auto
crypto map VPNS
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/4
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/5
no ip address
shutdown
negotiation auto
interface TenGigabitEthernet0/1/0
no ip address
shutdown
vrf forwarding Mgmt-intf
ip address 10.0.0.5 255.128.0.0
negotiation auto
interface Virtual-Template1
description l2tp
ppp authentication pap LDAPCIT
router ospf 10
router-id 10.88.88.88
area 0 range 10.0.0.0 255.0.0.0
ip default-gateway 10.0.0.1
ip http server
ip http authentication local
ip http secure-server
ip http secure-trustpoint border
ip forward-protocol nd
ip tftp source-interface GigabitEthernet0/0/0
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip route vrf Mgmt-intf 0.0.0.0 0.0.0.0 10.0.0.1
ip ssh server certificate profile
server
trustpoint sign vpn
ip access-list extended ACRYL
20 permit ip 10.0.0.0 0.255.255.255 host 10.149.88.1
ldap attribute-map CIT
map type sAMAccountName username
ldap server CIT
ipv4 10.0.0.65
attribute map CIT
bind authenticate root-dn CN=******,CN=users,DC=inet,DC=bsu,DC=by password 7 *****
base-dn DC=inet,DC=bsu,DC=by
search-type nested
search-filter user-object-type user)(|(memberof=cn=VPN,cn=users,dc=inet,dc=bsu,dc=by)(memberof=cn=VPN_Cabinet,cn=users,dc=inet,dc=bsu,dc=by)
mode secure
radius server CIT
address ipv4 10.0.0.75 auth-port 1812 acct-port 1813
key 7 *******
control-plane
banner login --- 10G ---
line con 0
stopbits 1
line aux 0
line vty 0 4
session-timeout 3600
privilege level 15
session-disconnect-warning 3000
transport input all
line vty 5 15
privilege level 15
transport input all
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
ntp server 10.0.0.65
ntp server vrf Mgmt-intf 10.149.8.2
end
Dima Dvorcovoy
Version without L2TP
Building configuration...
Current configuration : 21976 bytes
! Last configuration change at 17:01:07 MST Fri Dec 10 2021 by dimad
version 17.5
service internal
hostname Border-New
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
ip domain name bsu
vpdn enable
vpdn-group pptp
accept-dialin
protocol any
virtual-template 2
source-ip 10.8.8.8
username dimad privilege 15 password 7 ***************
redundancy
mode none
cdp run
negotiation auto
negotiation auto
no ip unreachables
load-interval 30
ip virtual-reassembly
ip http server
server
trustpoint sign vpn
ip access-list extended 111
10 permit icmp any any
radius server CIT
address ipv4 ********* auth-port 1812 acct-port 1813
key 7 *************
control-plane
banner login ^C--- 10G ---^C
line con 0
stopbits 1
line aux 0
line vty 0 4
privilege level 15
transport input all
line vty 5 15
privilege level 15
transport input all
call-home
active
it is getting a bit confusing since you are sending different versions of your configuration. Either way, are your VPN client PCs (the Windows 7 PCs) able to ping the Loopback1 IP address ?
In any case, take out the line:
I put different versions I tried - and all with the same result: connection established, IP issued,  ping FROM client to remote device is delivered to that device, responses are accepted packets delivered to this ASR, but there ARE NO INCOMING PACKETS on client.
I think there are some bugs on ip - tunneling encapsulation process. What have I to turn on debug to check it?
Can you give me a working sample of PPTP server configuration? Just simple pptp, no crypto-certificates-accounting etc.
your config looks fine. I have a feeling that the problem is related to the Windows 7 client, which is obviously rather outdated. What if you enable split tunneling as in the short video described below (provided of course you are using the default, which is a full VPN tunnel)...
https://www.youtube.com/watch?v=La4YX-8BnAo
Author and talk show host Robert McMillen explains how to split the tunnel traffic in a Windows 7 VPN connection . This How To Video also has audio instruction.
I am very angry, when somebody gives me "priceless" advices alike. No, most our clients are Windows 7, or even XP. If you have will to donate some thousands computers to our University, I can give you contacts.
And more, if you want to say something, please do it in text form. No video clips, rock music ballads, 3D presentations, abstract paintings. Just some words.
--> Can you give me a working sample of PPTP server configuration? Just simple pptp, no crypto-certificates-accounting etc.
PPTP is not supported at all on the ASR 1000 series.
Check the link below, there is a 'Note' at the bottom of Figure 1:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/vpdn/configuration/xe-16-7/vpd-xe-16-7-book/vpd-tech-overview.html#GUID-9E050FF0-D421-423F-AF68-B7CDA2B22D4B
