ASR 1002-x / QOS Issue
ammar-taha
Hello
I run QOS to police youtube traffic and use cbQosCMPrePolicyBitRate (1.3.6.1.4.1.9.9.166.1.15.1.1.11.)  OID to monitor the amount of youtube traffic in PRTG software , the issue is when the traffic Exceed 4300 Mbps the router stop send the right policy-map value it send random numbers this issue happen to all my routers ,when i check it inside the router using
show policy-map interface
it show the right value but it send wrong one over SNMP
Mark Elsen
         - Check current software version on your ASA, use an advisory release if applicable  , check if that helps.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hello dear
thank you for your reply , it's ASR not ASA and this issue happen on 4 routers with different software version
          - Same advice still applicable.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
