ASR 1004 Etherchannel
pkumarap
I need to configure LAG on ASR 1004.Will ASR 1004 support PAGP and LACP?How to configure ether channel?ASR 1004 is running on XE 2.3.0 version.please help
Giuseppe Larosa
Hello Pramod,
I've found a chapter about etherchannel in IOS XE switching config guide
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_cfg_gecvlan_ps9587_TSD_Products_Configuration_Guide_Chapter.html
one specific feature of ASR is the per vlan load sharing.
the interface configuration guide for IOS XE actually sends to a generic IOS page
http://www.cisco.com/en/US/docs/ios/interface/configuration/guide/ir_cfg_lan_if_ps9587_TSD_Products_Configuration_Guide_Chapter.html#wp1111570
Hope to help
Giuseppe
Thank you
jshake
I had an issue where traffic would not traverse the etherchannel from an ASR1k to a 4900M catalyst. The issue was ultimately the missing command that is mandatory it seems in etherchannel for ASR.
port-channel load balencing vlan-manual I believe it was.  Once i popped that in there on default the link came up and protocol established across the PO.
Mine was a l3 so I had to throw a tagged sub interface on the PO1 and tag it on the 4900 side also.
Thanks..
