ASR 1006 not being able to bring an interface up
gaboughanem
I have 2 ASR 1006 with ASR-1000-ESP40, ASR-1000-SIP40, ASR-1000-RP2 , and with SPA-1X10GE-L-V2 that should hold an XFP-10G-MM-SR.
i am in the proceed of an implementation and configuration, but i am facing a problem on the interfaces, where i am not able to bring the interfaces up/up and always  down/down.
i check the fiber patch cords and the other SFP on the switch WS-C3560E-12D and it is working fine. i also reverse the fibers pins and nothing works
i am getting frustrated about this issue and not able to fix the problem, i need only to get the interface to be up/up.
i also checked all the hardware compatibility matrix, IOS XE, the SPA are all online (show platforms).... where all seems to be ok and compatible.
all what is needed is to give the interface ,for example, tengig0/0/0 and ip address and no shut and it should go up/up.
One more thing, the XFP is not giving a red light laser, and in the show interface tengig0/0/0 give media type is unknown.
Anyone has faced this problem before. i appreciate any help.
Thank you and Regards,
George
Leo Laohoo
You may have a bad 10 Gbps SFP module.
Can you loop it?
