ASR 1K license
gaboughanem
I have an ASR1006 and I want to install a license (FLASR1-NAT64-2M) but there are NO license commands on the router!!!!
Please can anyone help in this?
Thank you
George
Router#sh license ?
% Unrecognized command
Router#debug license ?
Router#install ?
Router#install license ?
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.2(4)S, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 23-Jul-12 20:02 by mcpre
IOS XE Version: 03.07.00.S
Cisco IOS-XE software, Copyright (c) 2005-2012 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 2 weeks, 2 hours, 14 minutes
Uptime for this control processor is 2 weeks, 2 hours, 15 minutes
System returned to ROM by reload at 16:11:41 UTC Tue Apr 16 2013
System restarted at 15:26:52 LIB Mon Jul 1 2013
System image file is "bootflash:/asr1000rp2-adventerprisek9.03.07.00.S.152-4.S.bin"
Last reload reason: Critical software exception, check bootflash:crashinfo_RP_00_00_20130701-051812-UTC
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1006 (RP2) processor with 4231175K/6147K bytes of memory.
Processor board ID FOX1644G1AK
10 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1925119K bytes of eUSB flash at bootflash:.
78085207K bytes of SATA hard disk at harddisk:.
gaboughanem
anyone.....
