ASR 9001 and 1004 BGP configuration
lmanavalan
When i tried to bring up eBGP peering between ASR 9001 and 1004 its give me error message
"BGP_SESSION-5-ADJCHANGE: neighbor <peer ip> IPv4 Unicast vpn vrf dp topology base removed from session  Peer closed the session".
ASR 9001 runs on asr9k-os-mbi-4.3.2/0x100000/mbiasr9k-rp.vm
and ASR 1004 asr1000rp1-adventerprisek9.03.04.04.S.151-3.S4.bin
Is there any specific configuration for bring up the peering between these two type of Code and model.
Logesh
can you post the output of 'sh interface x' from both neighboring interfaces ? This could be an MTU size problem, or a problem with the duplex settings.
This peering is not on directly connected interface. Its a multi hop eBGP using loopback address.
regards
Logesh
