asr 901 licensing problem
milko.ilari
Hello All,
I have a brand new asr 901 with IOS asr901-universalk9-mz.152-2.SNH1.bin
I tried to upgrade license to AdvancedMetro and I received following output:
SW-ME-LAG-901#license install flash:CAT1649U0W3_201408010022219070.lic
Installing licenses from "flash:CAT1649U0W3_201408010022219070.lic"
Installing...Feature:AdvancedMetroIPAccess...Successful:Supported
1/1 licenses were successfully installed
0/1 licenses were existing licenses
0/1 licenses were failed to install
SW-ME-LAG-901#
*Aug  4 13:44:13.547: Following corrupted license storage was un-recoverable : lic0:/lservrc.pri
*Aug  4 13:44:13.547: -Traceback= 2618B98z 5F0DFE4z 5F0BC80z 5F0C2C4z 561C644z 5617ADCz
*Aug  4 13:44:18.463: %LICENSE-2-UNRECOVERABLE: The IOS license storage on this device was not recovered. UDI=A901-12C-F-D:CAT1649U0W3
*Aug  4 13:44:18.467: Following corrupted license storage was un-recoverable : lic0:/lservrc.pri
*Aug  4 13:44:18.471: -Traceback= 2618B98z 5F0DFE4z 5F0BC80z 5F0C2C4z 561C644z 5617ADCz
*Aug  4 13:44:19.067: %LICENSE-2-UNRECOVERABLE: The IOS license storage on this device was not recovered. UDI=A901-12C-F-D:CAT1649U0W3
*Aug  4 13:44:19.283: Following corrupted license storage was un-recoverable : lic0:/lservrc.pri
*Aug  4 13:44:19.283: -Traceback= 2618B98z 5F0DFE4z 5F0BC80z 5F0C2C4z 561C644z 5617ADCz
*Aug  4 13:44:20.147: %LICENSE-2-UNRECOVERABLE: The IOS license storage on this device was not recovered. UDI=A901-12C-F-D:CAT1649U0W3
*Aug  4 13:44:20.151: Following corrupted license storage was un-recoverable : lic0:/lservrc.pri
*Aug  4 13:44:20.151: -Traceback= 2618B98z 5F0DFE4z 5F0BC80z 5F0C2C4z 561C644z 5617ADCz
*Aug  4 13:44:20.719: %LICENSE-2-UNRECOVERABLE: The IOS license storage on this device was not recovered. UDI=A901-12C-F-D:CAT1649U0W3
*Aug  4 13:44:20.723: Following corrupted license storage was un-recoverable : lic0:/lservrc.pri
*Aug  4 13:44:20.723: -Traceback= 2618B98z 5F0DFE4z 5F0BC80z 5F0C2C4z 561C644z 5617ADCz
*Aug  4 13:44:21.295: %LICENSE-2-UNRECOVERABLE: The IOS license storage on this device was not recovered. UDI=A901-12C-F-D:CAT1649U0W3
*Aug  4 13:44:21.299: Following corrupted license storage was un-recoverable : lic0:/lservrc.pri
*Aug  4 13:44:21.303: -Traceback= 2618B98z 5F0DFE4z 5F0BC80z 5F0C2C4z 561C644z 5617ADCz
*Aug  4 13:44:21.875: %LICENSE-2-UNRECOVERABLE: The IOS license storage on this device was not recovered. UDI=A901-12C-F-D:CAT1649U0W3
*Aug  4 13:44:21.879: Following corrupted license storage was un-recoverable : lic0:/lservrc.pri
*Aug  4 13:44:21.879: -Traceback= 2618B98z 5F0DFE4z 5F0BC80z 5F0C2C4z 561C644z 5617ADCz
*Aug  4 13:44:22.455: %LICENSE-2-UNRECOVERABLE: The IOS license storage on this device was not recovered. UDI=A901-12C-F-D:CAT1649U0W3
*Aug  4 13:44:22.511: %LICENSE-6-INSTALL: Feature AdvancedMetroIPAccess 1.0 was installed in this device. UDI=A901-12C-F-D:CAT1649U0W3; StoreIndex=1:Primary License Storage
*Aug  4 13:44:23.111: %LICENSE-6-RECOVERED: The IOS license storage on this device was recovered. UDI=A901-12C-F-D:CAT1649U0W3
*Aug  4 13:44:23.115: %LICENSE-6-RECOVERED: The IOS license storage on this device was recovered. UDI=A901-12C-F-D:CAT1649U0W3
*Aug  4 13:44:23.119: %LICENSE-6-RECOVERED: The IOS license storage on this device was recovered. UDI=A901-12C-F-D:CAT1649U0W3
*Aug  4 13:44:23.123: %LICENSE-6-RECOVERED: The IOS license storage on this device was recovered. UDI=A901-12C-F-D:CAT1649U0W3
*Aug  4 13:44:23.127: %LICENSE-6-RECOVERED: The IOS license storage on this device was recovered. UDI=A901-12C-F-D:CAT1649U0W3
*Aug  4 13:44:23.131: %LICENSE-6-RECOVERED: The IOS license storage on this device was recovered. UDI=A901-12C-F-D:CAT1649U0W3
*Aug  4 13:44:23.135: %LICENSE-6-RECOVERED: The IOS license storage on this device was recovered. UDI=A901-12C-F-D:CAT1649U0W3
SW-ME-LAG-901#
After reboot IPBase is always in use and not advanced.
SW-ME-LAG-901#show license
Index 1 Feature: AdvancedMetroIPAccess
        Period left: Life time
        License Type: Permanent
        License State: Active, Not in Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: IPBase
        License State: Active, In Use
SW-ME-LAG-901#
I tried to changed priority and output is:
SW-ME-LAG-901#license modify priority IPBase low
% Error:  License priority modification failed: Invalid operation
What can I do?
Thanks!
Milko
0 Replies 0
