ASR 903 BDI interface not pinging from Cisco 3560CG
bn.thiyagarajan
There is an indirect connectivity between ASR 903  router and Cisco 3560CG router for which the configured to be in same IP segment. The two devices are not pinging from each other, but able to ping other devices from both which are in the same LAN segment.
Router:
interface Po4
service instance 600 ethernet
description COLLECTOR
encapsulation dot1q 600
rewrite ingress tag pop 1 symmetric
bridge-domain 600
interface BDI600
ip address 100.66.44.9 255.255.254.0
no ip redirects
no ip unreachables
CA93-01#ping 100.66.44.1
Sending 5, 100-byte ICMP Echos to 100.66.44.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
MH-MUM-GFD-B1-ST-MCM-MRT-CA93-01#ping 100.66.44.20
Sending 5, 100-byte ICMP Echos to 100.66.44.20, timeout is 2 seconds:
Success rate is 0 percent (0/5)
CA93-01#sh ip arp | i 100.66.44.20
Internet 100.66.44.20 114 f078.16bd.6741 ARPA BDI600
Switch:
3560CG#sh run interface vl600
Building configuration...
Current configuration : 110 bytes
interface Vlan600
ip address 100.66.44.20 255.255.254.0
3560CG#ping 100.66.44.9
Sending 5, 100-byte ICMP Echos to 100.66.44.9, timeout is 2 seconds:
3560CG#sh ip arp | i 100.66.44.9
Internet 100.66.44.9 0 188b.454c.5cbf ARPA Vlan600
One thing is in arp table of the switch, arp for that particular router is continuously flushing and always is "0". On the other end, in router there is
no problem, the arp for the switch is aging.
Warm Regards.
0 Replies 0
