ASR 903 memory
clark white
Level 2
Level 2
Dears,
I have ASR 903 router whose memory utilization reaches to 50% and the show process  cpu  is only 14%. I want to know where the memory is been utilized for, and is it whether this is normal for ASR router's???
I have just uploaded the suggested software from Cisco.
5 Replies 5
Vinit Jain
IOS on ASR903 runs as a process (IOSd) process on the linux kernel. Thus, some resources are consumed by Linux kernel and other processes including IOSd process.
You can check the system utilization using the below command:
- show platform software status control-processor brief
Also, please share the output of "show memory statistics"
Vinit
--Vinit
Hello
Here is the attached for sh memory output ,currently I don't have for  show platform software status control-processor brief
what is the trick to find out the most memory utilizing process from the output attached, and what does that process actually doing in the router.
Here is the attached sh memory output ,
it seem it was not uploaded in previous post.that I have uploaded again.
Could you also share the output of below commands as well:
- show version
Vinit
--Vinit
Dear vinit
Load Average
Slot  Status  1-Min  5-Min 15-Min
  RP0 Healthy   0.18   0.30   0.26
Memory (kB)
Slot  Status    Total     Used (Pct)     Free (Pct) Committed (Pct)
  RP0 Healthy  3438132  1828548 (54%)  1609584 (46%)   1666372 (48%)
CPU Utilization
Slot  CPU   User System   Nice   Idle    IRQ   SIRQ IOwait
  RP0    0   6.40   5.40   0.00  87.80   0.00   0.40   0.00
         1   3.10   1.90   0.00  93.59   0.30   1.10   0.00
sh ver
Cisco IOS XE Software, Version 03.16.03a.S - Extended Support Release
Cisco IOS Software, ASR903 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.5(3)S3a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
ROM: IOS-XE ROMMON
System image file is "bootflash:asr903rsp1-universalk9_npe.03.16.03a.S.155-3.S3a-ext."
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Type: Permanent
cisco ASR-903 (RSP1) processor (revision RSP1) with 929939K/6147K bytes of memory.
16 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3670016K bytes of physical memory.
1328927K bytes of SD flash at bootflash:.
