ASR 9K BGP Session is stuck in IDLE between OCI FC
Giuseppe Larosa
Hello @CarsonDavis56998 ,
see the following recurrring error message:
RP/0/RSP0/CPU0:Oct 4 00:52:23.573 : bgp[1051]: %ROUTING-BGP-5-ADJCHANGE : neighbor 10.92.127.249 Down - BGP Notification received, maximum number of prefixes reached (VRF: SG) (AS: 31898)
The other side has configured a max number of prefixes it can learn from your device you need to change your outbound route policy that is currently permitting all prefixes in the table of VRF SG to be sent to the peer.
Hope to help
Giuseppe
Thanks for the reply, would you suggest I do an aggregate-summary to summarize routes going out to my peer? Perhaps advertise RFD1918 and a default route, which would only give the peer 4 total prefixes?
Can you share
Ip bgp summary
