asr 9k issue ipv4
hello Everybody,
today i have got repeted on 15 sec this message on asr9k:
%ROUTING-FIB-3-PLATF_UPD_FAIL : FIB platform update failed:
Obj=DATA_TYPE_NHINFO[ptr=b55c60f8,refc=0x3,flags=0x3] Action=MODIFY Proto=ipv4.
Cerr='FIB' detected the 'warning' condition 'Invalid argument'
my devise has:
System image file is "bootflash:disk0/asr9k-os-mbi-5.3.4/0x100000/mbiasr9k-rp.vm"
cisco ASR9K Series (MPC8641D) processor with 8388608K bytes of memory.
MPC8641D processor at 1333MHz, Revision 2.2
ASR 9006 4 Line Card Slot Chassis with V2 AC PEM
0/RSP0/CPU0     A9K-RSP-8G(Active)        IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP-8G(Standby)       IOS XR RUN       PWR,NSHUT,MON
0/0/CPU0        A9K-40GE-L                IOS XR RUN       PWR,NSHUT,MON
0/1/CPU0        A9K-8T-L                  IOS XR RUN       PWR,NSHUT,MON
can you please know i can resolve this?
BR
chances are you are hiting the bug below:
FIB generates error/traceback after interface flap
CSCvb97274
Description
Symptom:
Following tracebacks are seen after every interface flaps with Error: Invaild Argument(EVAL)
LC/0/3/CPU0:Oct 28 14:59:28.177 UTC: fib_mgr[189]: %ROUTING-FIB-3-PLATF_UPD_FAIL : FIB platform update failed: Obj=DATA_TYPE_LOADINFO[ptr=9b7aa3e8,refc=0x1,flags=0x248289] Action=MODIFY Proto=ipv4. Cerr=Invalid argument :
Conditions:
Since the label is not present for that interface and whenever unlabeled interface flaps traceback is generated with return code is EVAL.
Workaround:
None.
Further Problem Description:
There is no point in sending the EVAL return code for unlabeled flag , so we are ignoring the tracebacks for unlabeled flag by checking the traceback flags is unlabeled or not
Last Modified:
Jan 12,2020
Status:
Fixed
Severity:
3 Moderate
Product: (1)
Cisco ASR 9000 Series Aggregation Services Routers
Support Cases:
Known Affected Releases: (1)
5.2.4.FWDG
Known Fixed Releases: (36)
7.0.11
7.0.1
7.0.0
6.6.25
6.6.12
6.6.11
6.6.2
6.6.1
6.5.93
6.5.92
6.5.90
6.5.28
6.5.26
6.5.25
6.5.15
6.5.3
6.5.2
6.5.1
6.4.2
6.4.1
6.4.0
6.3.15
6.3.3
6.3.2
6.3.1
6.2.25
6.2.3
6.2.2
6.2.1
6.1.45
6.1.42
6.1.33
6.1.32
6.1.31
6.1.4
6.1.3
Thanks a lot for reply.
I think the big is not this one exactly because the error is slightly different.
Nevertheless how can I solve the problem i cannot update my ios xr because the rp 8g is at 5.3.2 and it is the latest available. Any suggestions?
