ASR Can ping OTHER ASR over Verizon PIP (BGP) But Cannot Ping Devices
sak99384
I have been banging my head for days on this one. Working on a network where we had a CE router fail (power supply issue) that was doing BGP over a Verizon private line.  Replaced router with like model, loaded backup configuration, and while I can ping the router at each side (and each router can ping in to the local network,) I cannot hit any devices on the far side of either link, except the routers themselves. I have attached sanitized configs and ANY help is much appreciated.
Basic Network Layout:
Routes show in the bgp table on each side:
12 Replies 12
The defualt route learn via bgp but it with letters "r"
Which meaning that RIB have same prefix with less AD.
So what you need is make RIB prefer prefix via BGP by reduce AD of other path.
Note :- ebgp have ad 20
If you are talking about my routing tables, I don't see any routes that are "r" the ones that I am trying to hit are marked "i" on each side.
Show ip bgp <<- this output you share for what ?
Yes. I shared for both routers.
r> 0.0.0.0 this IP is failure
Can I know prefix you need to ping via bgp and show ip route for both router
Sure. Also, I forgot to mention, the local Meraki router/FW is at 10.77.255.1 and 10.78.255.1 . This is the gateway to the rest of the local network on each side.
The traffic is used gw which is FW not use Router to reach other site.
The solution is using hsrp between two router and FW and make GW of host is VIP of HSRP.
Is HRSP the only way? I do not understand why this config worked for years prior, and then didnt, just on equipment swap.
Hmm,
Is there any pbr config on router or FW?
No there is not.
sak99384
The main FW/router is Cisco Meraki, and it is set to auto vpn the sites together if the site to site is down. Thanks for all of you help so far... thinking it has to be something simple!
Your bgp configuration based on the supplied topology is incorrect, both rtrs  in location A/B show that they share what looks like just the one private vpls line, are  in the same bgp ASN (1) and are peering to the same ISP ASN (6500)… this you don’t show.
So as it stands any advertise lan subnets advertised from either location rtr will NOT be accepted by either rtr due to the fact bgp will see its own As-path (1) in the bgp updates and not accept them.
Do you have any other connection from either location that connects and peers directly into the ISP because as it is presently your setup is incomplete and suggests the full topology is not being shown.
Kind Regards
Paul
