ASR Require a RTU License to use BGP
dvaggalis
Do I need to purchase a RTU license to use BGP?  Checking the Feature Navigator it looks like it is in the IP Base License, but  I thought that BGP was supported in an IP Services image.
Since there isn't an IP services license for the ASR software, do I need the Advance IP Services license?
looking at the ASR Ordering Guide, example 6, references needing the Enterprise license for BGP?
http://www.cisco.com/en/US/prod/collateral/routers/ps9343/product_bulletin_c07-448862.html
gephelps
What model are you looking at? The ASR1001 series is unique with licenses.
In general though a RTU license is a paper license which is not enforced through SW.
