ASR Router model
Hamada Ahmed
I need to choose an ASR1000 model to support 4000 branches, with 3 tunnel in each branch and with 50G to 80G
so which model should I use?
balaji.bandi
Personally these kinds of solutions i will engage a cisco partner, so your BoM and solution will work as expected, since its a large deploymernt, you may need Dual or more head-end devices based on the deployment models you looking to deploy for redundancy, what bandwidth each location also is this internet required here?
here some compare :
https://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/datasheet-c78-731632.html
BB
You are going to need ASR1002HX for that size. But, I recommend you to read the Data sheel carefully before anything.
Starting for network design. 4000 branches is a massive network and there´s a lot to consider here.
But ASR 1002-hx what is max. Tunnel interface can handle?
The maximum possible. It is the bigger one.
 Take a look on the data sheet
